Air in fuel line before pump?
Discussion in 'The Hokey Ass Message Board' started by 60GMCGUY, Aug 14, 2007.
  1. 60GMCGUY
    60GMCGUY
    I just replaced the pump on my truck because it kept cutting out but after sitting fo rafew minutes it would run fine agian the cut out. so i was going for a test drive to make sure everything was ok and it did it again,and again. so i look under the hood and the fuel filter it full,then i loosened the clamp on the inlet side of the pump and could hear air whistling and it was bone dry,stuck it back on and ran fine for a mile then did it again. anybody have any idea on whats going on?
  2. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Probably vaporlocking in the pump. Had a 69 camaro that did that until i plumbed in a return line and put on a pump with return line.
  3. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    But you might make sure the tank has a vented cap on it. The whistling you hear might be the tank ****ing air back in when you crack the fitting.
  4. 60GMCGUY
    60GMCGUY
    Ok i thought vaporlock was a heat problem. so basically i have air building up in the pump until it no longer lets fuel in?
  5. dave lewis
    dave lewis
    from Nampa ID
    try driving it with the fuel cap off. if it runs ok, the vent is plugged.most "old" cars had vented fuel caps and they are hard to find these days because of emissions. they dont want the nasty fumes venting to the atmosphere.
  6. 60GMCGUY
    60GMCGUY
    the cap vent is clear since i can blow air throught it. Just a dumb idee could i put a t at the output and run a small line back to the tank to bleed of air or would all my fuel want to follow that line
  7. rodknocker
    rodknocker
    are you sure your pump is putting out the psi you need?
  8. 60GMCGUY
    60GMCGUY
    good question,how can i tell?
  9. rodknocker
    rodknocker
    is it an electric pump off of the tank or the mechanical one at the engine?
  10. Notorious
    Notorious
    Fuel pressure gauge. Also, I've seen systems draw air in from the suction side w/o a corresponding fuel leak.
  11. dave lewis
    dave lewis
    from Nampa ID
    uuhhh, just because you can blow air thru the cap does not mean that its vented...lots of caps are "pressure relief" but not vented...as i sugested before, try driving without the cap and see what it does....
    dave :D
  12. HemiRambler
    HemiRambler
    Some of the older gas tanks have the fitting at the bottom. If there's any "gunk" in your tank it can slosh around and cover that fitting - all or partially. I had that problem on my '47. It'd drive fine for a little while then **** out. I'd crank it for a few seconds and it'd fire right back up - idle forever. In my case there was some **** flaking off the inside of the tank - it'd slosh around and SOMETIMES cover the fitting. It'd restrict the flow so that while driving it'd die, but it would allow enough to flow that when idling - it'd idle all day long. Just a thought.
  13. chopolds
    chopolds
    from howell, nj
    Check the condition of your rubber hoses between the fuel pump and gas tank. I had a doozy of a pain in the *** to diagnose, that the hose between the tank and frame rail was old, and porous. Wouldn't leak, but would **** air in under vacuum, and the car would cut out, run out of gas, even with a full tank!
