1961 Polysphere 318 in a 52 Dodge
Discussion in 'The Hokey Ass Message Board' started by nosyjoe, Aug 22, 2007.
  1. nosyjoe
    nosyjoe
    from california
    OK, so I got a poly 318 out of a 61 plymouth with the push ****on trans. The engine has been sitting since 1981 but with a little work it started up. Sounded great. ****** is ****ed up in reverse. But i kind of like the idea of putting a push****on shifter in a 52 so i might have it repaired. so here are the questions...
    I have heard of people putting a LA 273/318 in a 49-52 Mopar but has anyone done an A 318 aka poly, wide block in one?
    If I bought mounts from plydo, is it a straight swap in or am i looking at some cutting?
    Should I s**** the push****on idea since i have to repair the ******?
    This is my first build at this level (have only worked on complete cars) so any advise would be helpful.
    nosyjoe
  2. montclaire
    montclaire
    I would repair the trans for two reasons; one, the push ****on option is kinda funky, and two, it's cable operated so it makes the swap a little easier than adapting a regualr linkage. As for the poly motor, something is rattling around in the back of my head that says you can bolt early hemi heads onto them...
  3. Appleseed
    Appleseed
    You can't hemi-ize a 318. That only works with the older polys. Sorry. I thought the same thing.
  4. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    My shop just put a 318 wideblock in 38 plymouth pickup and in a customers 39 dodge coupe... Have pics and everything... It will fit... The smaller 318 would fit easier... but who wants easy??? Plydo mounts will work...you will probably have to convert the steering to rack and pinion on the car though.. The original box is in the way... Jason.
  5. 302GMC
    302GMC
    from Idaho
    Iron Torqueflite is a tough trans to beat for durability. If it's a Powerflite, I'd p*** on the rebuild.
  6. montclaire
    montclaire
    He says he has a poly motor? Or am I reading it wrong? He mentions an LA block, but I think that's just for conversation sake if he sources another motor.
  7. teddyp
    teddyp
    we put a 360 in a 52 dodge was pretty much a bolt in swap with a 4 speed
  8. pasadenahotrod
    pasadenahotrod
    from Texas
    Be advised that the push****on shift business from the donor may be, to my knowledge, the only shifting mechanism you can use with any MOPAR push****on shift trans. The mechanism is very sensitive to adjustment and may not be modifiable.
  9. montclaire
    montclaire
    Try a company called imperial services
  10. rjgideon
    rjgideon
    I've never worked with a Poly, but I can tell you that I am familiar with the push-****on autos. The swap should be okay, just don't cut your shift cables, those are expensive to replace. The shifter mechanism on the dash of the donor needs to be with the ****** as well, or your're going to have a hard time finding the pieces to make it work. Rebuilds of the push****on will be more expensive than a later 727, but not terrible. Pat Blais transmissions in WA are very familiar with the push****ons and have tons of parts in stock.
  11. 1973Swinger
    1973Swinger
    from Lima, NY
    You would be right on that, the early Hemi heads will fit on a Poly! :cool:
  12. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    EXCEPT..... the 318.. no go on the poly 318..Done the calling and the searching... Jason.
  13. Boynamedsue
    Boynamedsue
    The only bad thing about the push ****ons is they tend to stick in gaer, or out of gear. cold conditions kinda make them act up. But the torqueflite is a sturdy piece for sure parts for the rebuild and the shift cables are going to cost you an *** and a leg. But its mopar what doesnt break the bank when it comes to that.
  14. Yeah, Pat is the guy to talk to about old torqueflites.
    PM me if you need to get in touch and I'll give you his #.
    IIRC the side mounts on a 318 poly were the same as LA 318/273. If that's right, you should be able to shoehorn the block into the ch***is like the small block 46-8 swap shown in the Tex Smith book on hot rodding old mopars.
    Dunno about the exhausts; might have to make headers. But if the engine and the car are both nice, it'd be worth it.
    -bill
  15. nosyjoe
    nosyjoe
    from california
    sorry if i was unclear. i have a poly 318. i've seen people put a LA 318 in a 49-52. Never seen a poly in one. i'm sure plenty of folks must have done it. just trying to identify any major obsticles i might come across.
  16. I think Montclaire's not understanding there was a Poly 318, along with the earlier varietys (354, etc.) At least that's how I read it... The 354 variety does have the HEMI interchange, the later "A" block doesn't.
    The Poly 318 is the "A" motor, the Unpoly? 318 is the LA.
    I wondered if a 354 (poly, not HEMI) would fit in a 49, guess now I know.;) :D
    Jay
  17. montclaire
    montclaire
    I know about the poly 318s, but I am unaware of other poly motors. More than one displacement? Anyway, the LA blocks are lighter and make more power. Use a regular hi-po 340 cam and chrysler electronic ignition and you should be fine. Can use your push ****on trans, too.
  18. Yeah, I know there were at least the 277 and 301 style, along with the earlier 354 (Windsor motors, they called them;after the model, not the city).
    I wasn't trying to sound ****ish, but I guess after re reading it it sounds that way. Sorry! :)
    And it is correct that the A and LA blocks have the same bellhousing pattern, which is odd for Chrysler!
    Jay
  19. montclaire
    montclaire
    Oh, ok, I got it. For all the mopar mags I have laying around, and I mean stacks back to the early 90s that I have near memorized, the only poly I've ever heard mention was the 318 version. One of the biggest problems with early chysler stuff is that it doesn't interchange, even the things you would almost have to ***ume would, especially on engines of the same displacement. Early hemis are enough to give you a headache.
  20. George
    George
    There was a bunch of early Polys built on Dodge & Chr. early Hemi blocks that can be converted to Hemi.The late Polys 277, 301 Plymouth, 303, 318, 326 can't be converted.
  21. Chester Breder
    Chester Breder
    The factory police package 318s used 360 heads. i don't know the years.
  22. panic
    panic
    Convertible to hemi using same-brand parts only:
    Dodge 1955-57 poly 241, 259, 270, 315, 325 (also used in base-line DeSoto and some 1955-56 Plymouth)
    Chrysler poly 1955-58 301, 331, 354
    Not convertible:
    Plymouth/Dodge poly "A" 1956-67 277, 301, 303, 313, 318, 326
    No interchange with other brands:
    DeSoto hemi 1952-57 276, 291, 330, 341, 345
  23. Late 70's thru 88 I think. But those aren't poly's.:D
    Jay
  24. nosyjoe
    nosyjoe
    from california
    would love to see those pics!
  25. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    I will get them for you in the morning. They are at the shop on the computer.. Jason
