Miller mig ???
Discussion in 'The Hokey Ass Message Board' started by Hooligansince65, Aug 25, 2007.
  1. Hooligansince65
    Hooligansince65
    from Chicago
    Hello all, I'm lookin for a new welder. Not to sure a miller or maybe lincoln or hobart. I want it for some sheet metal and to weld some 1/4 to 3/8 steel. a mig-tig combo would be awesome but I dont want to go broke. Any one have good luck with what they bought any info would be Great Thanks, BB
  2. Spoon
    Spoon
  3. wilnotsam
    wilnotsam
    at school i always use the millermatic 251 (mig welder). digital displays and everything. welds really nicely. we also have a lincoln tig welder im getting pretty good at, but i cant think of the model. only thing about tig welders is theyre gonna cost you quite a bit, and if you get one a tig machine, make sure it has ac dc positive and dc straight so you can do every metal you could possibly want.
  4. Corvette64
    Corvette64
    I have a Millermatic 150 that I bought about 15 years ago. Never a bit of problem. Perfect size for this hobby. Great for sheetmetal work and up to 3/8" steel. I think the new version is a Millermatic 180.
  5. lodaddyo
    lodaddyo
  6. gary terhaar
    gary terhaar
    from oakdale ny
    I now own my first miller 251 mig i dont use it much but when i do it performs verry well. I mostly use tig welders i use to own a lincon idealarc 300 for 15 years and it worked well also but when i needed a part that was specific just for the power source dealing with lincon was a little difficult to say the least. i now own a sincrowave 300 and i love it for it alluminum i needed a switch for it and miller customer service was second to none .something you may not think about when buying a new welder but sometimes they do break and if a few bucks is all the differance my money would go to the one who could service it and quicklyand you know they never break at a good time,almost always on a sunday 10pm halfway through a weld.
  7. Just Gary
    Just Gary
    I've been learning to weld with a new Lincoln 140-C that I got for Fathers Day. It works great for 24 ga. up to ~1/4" (3/8" of you bevel the edges and make a couple of p***es).
    I highly recommend it.
  8. InDaShop
    InDaShop
    from Houston
    I'm another 251 owner/user. Love it!
    I can TIG but dont own one, too much $'s but its on the list. 251 does everything I need now. but of course the MIG welds aren't as ***y as the TIG. If you got the dough get a TIG, if not I recommend the 251 big time.
  9. oldmule
    oldmule
    from Colorado
    I started with a Lincoln 125 and changed to a Millermatic 175 about 6 years ago. I love mine, I wouldn't go back. I think the guns and feed systems are better built than the Lincolns. Even though you can change to a Tweco, I haven't needed to yet....
  10. Hooligansince65
    Hooligansince65
    from Chicago
    any one make a good combo.
  11. Scarebird
    Scarebird
    Alliance Vendor
    from Moita, PT
    Get a 220 machine, not a 120v setup - much smoother.
  12. scottybaccus
    scottybaccus
    I beat a buddy out of a new Miller 135 amp, 115 volt machine this summer. I have every confidence in it to 3/16, as it is advertised, but no way it is up to 1/4 or better on a regular basis. I think I'll aim for a 22v, 250 amp machine down the road so that I'll be ready for anything. Might even move up to a TIG.
  13. Hooligansince65
    Hooligansince65
    from Chicago
    what abough a mig/tig in one
  14. TagMan
    TagMan
    Check out the Hobart Handler 187. It's a 230v unit with 7 taps. Fantastic welder and, if you hit either Tractor Supply Co. (TSC) or Northern Tools at the right time, they can be had for under $600.00. I've had mine for about 8-months and have done a **** load of welding with it and I love it !!
  15. DirtyTace
    DirtyTace
    I have a Hobart Handler 140 - Nice machine, essentially a Miller - (the gun even says "Miller" on it. Nice and cheap but I wouldn't buy it again. Step up to a 220 machine. Buy the biggest welder you can afford - I ignored this because I was broke at the time but I will be stepping up soon and when I do, it will be a Tig. But Hobart is less expensive and seems to have decent quality. I too got mine at Tractor Supply and they can have some good deals if you catch them at the right time.
  16. Hooligansince65
    Hooligansince65
    from Chicago
    about just had some coffee
  17. straight axle
    straight axle
    from Oregon
    i have a millermatic 175 and love it. two of my boy's use it too (5&9). Easy to use and works really well.
  18. Harms Way
    Harms Way
    My preference is always a Miller,... Hobart is built identically but it seems not built as well, and I was told with cheaper parts ( I don't know this for a fact, could be the same machine, Hobart is owned by Miller),.... I have never had any luck with Lincoln.
    I have never had a combination machine.
  19. Scrap Heap
    Scrap Heap
    I have a Lincoln that I bought at a home improvemeant store( a 110 machine). It does fine on light guage but I wouldn't weld anything heavier 1/8" with it. I want to upgrade to the Miller 180. I have a 220 outlet for my dryer in the garage, it is 30A. Have any of you used your dryer outlet to run your welder?
  20. Fast Fords
    Fast Fords
    from MN
    The Miller 252 is the latest and greatest. Better features than the 251. The price is about the same.
  21. bobscogin
    bobscogin
    To do both MIG and TIG on the same machine you'll need one capable of both constant voltage and constant current. Those are expensive (by my standards) and usually required a separate wire feeder for MIG. Here's a Miller: http://www.millerwelds.com/products/multiprocess/shopmate_dx/
    Bob
  22. Hooligansince65
    Hooligansince65
    from Chicago
    Thanks your right. Thats a lot of cash. maybe I will just run with one and not both. Ok if you had to pick just one to buy mig or tig for doing floor replacement and general light fab stuff what do you think....
  23. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    And by the time you add a wire feed, tig torch, cooler, two bottles of gas (tig likes straight argon while mig likes a mix) etc. you're probably looking at 4 to 5 large. On top of that, its a d/c only power source.
  24. Johnny99
    Johnny99
    Stick with a name brand, makes consumables and parts much easier to get. As mentioned earlier spend the extra $ and get a 220 volt machine. Personally I prefer Miller, my old Millermatic 35 is probably older than a lot of guys who post on here, [I bought it used 20 years ago] it has had miles of wire run through it. 3/8 plate fabrication can be to much for some of the smaller machines, there is a little thing called cold lap, [lack of fusion] that can bite you! joint preparation and design will help. I still go back to stick welding on heavier stuff, and with a little practice stick can be pretty to! Just my two cents worth. Good luck John
  25. Otto's
    Otto's
    from Tampa
    Got a miller 210, 135 and my buddy has a miller plasma. I will never buy anything else.
  26. Hooligansince65
    Hooligansince65
    from Chicago
    There is a miller 212 on eBay 1500 bucks looks nice.
  27. Stu D Baker
    Stu D Baker
    from Illinois
    Check your pm's. Stu
  28. Hooligansince65
    Hooligansince65
    from Chicago
    Thanks but I'm going new.
  29. Stu D Baker
    Stu D Baker
    from Illinois
    No problem. In the event that you hear of someone locally that might be a buyer for a used Millermatic 35, please let me know. Stu
  30. Dukeofbluz
    Dukeofbluz
    Millermatic 175
