Picked up a cheap homebuilt English wheel
Discussion in 'The Hokey Ass Message Board' started by oktr6r, Aug 25, 2007.
  1. oktr6r
    oktr6r
    from Tulsa
    I ran across an ad for an English wheel on Craigs list last night for $15. I knew it'd be homebuilt, which was what I had planned on doing at some point anyway. Hard to go wrong for that price.
    The frame is made from 2" pipe, with steel castors for the wheels. The rounded one looks like the radius may have been done in the guy's shop at home, very nice job on that part.
    It's crude, but should be something to play around with and learn on. Just in time to try making body panels for the Fiasco too... I'll post pics later.
    The guy had a couple of s****s around he'd messed with, looks like it'll put a decent shape in the steel. This could be fun...
  2. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Pipe isn't the best material for an e wheel frame, to much twist in
    all the wrong places. What's the wall thickness of the pipe. Maybe
    you can wrap the pipe in U-channel steel and "beef" up the design.
    This wheel may be a good choice for small patch panels in thin
    gage sheet. Anything thicker than 20 gage is going to require a
    much stronger frame for high crowned work.
    Good luck, have fun,
    S****ey Devils C.C.
  3. oktr6r
    oktr6r
    from Tulsa
    I figured it might not work for heavier steel. What about 2" x 1/4" wall square tubing, or even 2 1/2" x 1/4" wall? The wheels were worth the $15 to me to learn with. I have enough s**** to build a decent frame.
  4. OLDSKEWL61
    OLDSKEWL61
    ide try it first if you have problems then fix it. too many people say "it should be" or "that wouln't work" and......Suprise usually it works just fine!!!!!
  5. 15$ sounds great, try buying the wheels for that! Best show us how good it DOES work for that price AND its not HF!
  6. 51 MERC-CT
    51 MERC-CT
    If it does what you want it to do for $15 bucks it's a steal. Why over engineer it with unnecessary modifications?:) :D
  7. oktr6r
    oktr6r
    from Tulsa
    He showed me a couple of pieces he'd messed with, it did a great job for him. I tested a piece of 18 gauge, it's very slow making it do anything, but seems to be working.
  8. oktr6r
    oktr6r
    from Tulsa
    The wheels look like steel casters. The small one has been machined to get the radius needed. I need to make a wheel for the tension adjuster, it requires a wrench to tighten it right now.
  9. oktr6r
    oktr6r
    from Tulsa
    For $15, it should be good enough to learn a little, and smash a couple of finger tips. We'll see how it works out.
  10. FrankBoss
    FrankBoss
    you do know theres a guy in Edmond that makes kits and wheels ..sometimes you'll see them on E-Bay...
    but for 15.00 you can paint it black put a flower pot on it and call it garden art.
    Frank
  11. publicenemy1925
    publicenemy1925
    from OKC, OK
    WTG on the wheel. It's funny how the naysayers come out to say it won't work. I made mine outta a homemade headache rack from a dodge dakota, a strut compresser for the tensioner and a two car jack wheels, one crowned, one flat. It works really well and it was free. Great score!
  12. any pictures yet?
  13. pimpin paint
    pimpin paint
    from so cal
    Hey,
    I've seen some very usable e wheel frames made from lighter square
    tubing. They've all incorporated space-frame design principles-it's a
    question of do you turbo charge a four cylinder, or relie on a big block
    to get the job done?
    The caster type anvils should hold up fine, providing you don't wheel
    over any welds.
    S****ey Devils C.C.
  14. Unkl Ian
    Unkl Ian
    Depends on the size of the throat.
    2 x 2 x 1/4" wall might be fine for a small frame,
    or no where near close on a larger frame.
  15. oktr6r
    oktr6r
    from Tulsa
    Didn't know that, I'll have to check that out. I'd like to have some more wheels.
  16. oktr6r
    oktr6r
    from Tulsa
    Cool, any pics of it?
  17. oktr6r
    oktr6r
    from Tulsa
    Yeah, finally... It's made to clamp on to a bench. I have a '68 Chevy truck with a flatbed parked right beside the garage, works great to clamp it to.
  18. oktr6r
    oktr6r
    from Tulsa
    About an 18" throat. It's sch. 40 pipe, .154" wall.
    I have plenty of square tubing that's 1/4" wall, it I need to, I'll just build a better frame.
  19. Unkl Ian
    Unkl Ian
    Generally,the vertical member wants to be heavier
    than the rest of the frame.
    Some people add gussets to the corners,but that
    doesn't stop the vertical from flexing in the middle.
  20. publicenemy1925
    publicenemy1925
    from OKC, OK
    I have to get the camera from my daughter and post some pics. I like yours should work. Pretty doesn't mean performance.
  21. sawzall
    sawzall
    the frame will be fine..
    some flex is OK.
    however.. try to shim the lower wheel (caster) so that it doesnt move left and right as you move the material through the wheels.
    also..
    it appears that the lower wheel is ****ed to one side.
    IF you can make the axle of the lower wheel parallel with the axle of the upper wheel.. the tool MAY be more predictable..
    heres a shot of what I was working with..
    but I've recently upgraded to better wheels (the new upper wheel I have is a VERY LARGE ROLLER BEARING..)
  22. oktr6r
    oktr6r
    from Tulsa
    Good info there. I'll keep that in mind if I decide to build a frame for it.
  23. oktr6r
    oktr6r
    from Tulsa
    Good eye, I didn't notice the lower wheel not being straight until I took the pics. Should be easy enough to shim and fix the axle.
  24. budd
    budd
    have you tried using your wheel yet?, what have you made?, the little wheels i have made out of bearings, i just use to take the dents from forming the part with a piece of wood and gas bottle top with a piece of pipe welded to it for a handle. i have two nice bearings i'm going to use as upper wheels on my next wheels. i need to make a radius cutter for my lathe so i can make different lower wheels.
  25. pimpin paint
    pimpin paint
    from so cal
    Hey,
    If you polish the upper wheel, and the lower anvil with 180, 220, 320
    paper on a DA sander , they will leave your finished panels looking
    like a mirror. This is probably not a biggie for rough-formed patch
    panels that will be "mudded in", but if your going for little or no filler
    this will be a big help. Too, a mirror surface on the panel will help to
    spot bad tracking patterns "row crops" and misshapen areas on the
    panel.
    Turn the wheels on their axels by spinning them with a drill motor
    that has a rubber wheel/axel chucked in place, clamped to the
    frame of the e wheel. Once polished, keep them well oiled when not
    in use to prevent rusting.
    S****ey Devils C.C.
