Features Falcons done right?
Discussion in 'The Hokey Ass Message Board' started by guiseart, Nov 20, 2005.
  1. Falcon Gasser
    Falcon Gasser
    Here is a picture of my 60 Falcon G***er. It has a 351W and a C4 trans going to a 9 inch Ford rear end out of a 1966 Bronco and I use an 1965 Econoline front axle. Thanks
    Jon
  2. Ford Freak
    Ford Freak
    Very cool! What's the rear end ratio? What did you have to do tothe C-4 to make it live? What kind of times does it turn?
    Bernie
  3. Falcon Gasser
    Falcon Gasser
    I use a 4.56 axle ratio, the C4 was just built with high performance clutch's and TCI valve bady and converter with a hardend input shaft. The best its run was 2 years ago and that was a 11.60 at 118 m.p.h. Its 11.70's in the cool weather and 11.90's to 12.00's in the heat at are local tracks. If you go were there is any elevation it falls off quick into the 12 teens. Putting together a new motor over the winter and hope to run 11.50's in good air and 11.70's in the heat.
    Jon
  4. current list of falcon 1320 times:
    http://fordsix.com/forum/viewtopic.php?t=41798&highlight=
  5. Von Snacks
    Von Snacks
    Here is my contribution to one of the longest running threads of all time.
    This is my wife's 62. Sorry the pics kinda ****, but you get the idea.
  6. I cant beleive this threads still cruzin..lol
    Eric;..the car looks great !!...i really have to get my *** in gear with my 61!!
    just so ya know who this is..lol
    this is my good weather daily....WagonsHo
  7. Richard
    Richard
    from Rocklin,CA
    I love this thread.
  8. Bigcheese327
    Bigcheese327
    That red convertible reminds me of this one.
    -Dave
  9. falconizer_62
    falconizer_62
    any more pics of the tailfins? I was mocking some up on mine with Card board to see what it would look like. A few more angles would be nice
  10. garvinzoom
    garvinzoom
    [​IMG][​IMG]
    Here is the 62 I just got last weekend. Cant wait to get it on the road! This thread is killer!
  11. blktopbandit
    blktopbandit
  12. Mark in Japan
    Mark in Japan
    My old Falc
      71.6 KB
      73.7 KB
      78.3 KB
      78.9 KB
  13. BigRed390
    BigRed390
    God, I LOVE THAT CAR!!!!:eek: Don't know what it is about it, but it's just awesome!!
  14. Mark in Japan
    Mark in Japan
    magenta with violet pearl flames and silver flake roof!!!!
  15. chromedaddyo
    chromedaddyo
    from Ohio
    "Chris' Falcon" AWB G***er,,,,Workin hard in this photo,and no it is not on a jack!
    Dave
  16. Machobuck
    Machobuck
    And I thought my falcon had a radical stance! Any other shots?
  17. garvinzoom
    garvinzoom
    Thank you!!
  18. chromedaddyo
    chromedaddyo
    from Ohio
    Can't let the cat out of the bag just yet! Just a teaser shot! The back will go up a little bit (not crazy) and it is getting lettered in 60's drag car style. It has a very, very healthy 302, C-4, 4-11 rear. Should be a total blast when Chris gets it done.
    Cleveland and Thompson drag raceway will be nuts with g***ers next year!
    Dave
  19. falconizer_62
    falconizer_62
  20. Beach Hop
    Beach Hop
    Sorry about the late reply. Will have to hunt and see if I can find some more photos. We used 1" exhaust tube cut on a taper at the door end and screwed to the panel 1/2" from the end. At the tail light end I drilled a 1/4" hole in the top of the fender and under the exhaust tube and used a length of threaded rod with locking nut to raise and lower the heigh of the exhaust tube until we got the desired look. When we were happy we made cardboard templates to fill in the panel between the car and exhaust pipe, cut out these shapes in sheet metal and then welded them in. The threaded rod was then removed and a quick grind and smear of body filler finished them off.
    I hope this helps!
    Noddy
  21. garvinzoom
    garvinzoom
    Yeah, some more pics of that car would be awesome. Looks good with those fins.
  22. Beach Hop
    Beach Hop
    Found some pics! Remember this started as a 4 door sedan (rusty) and ended up finished as a 2 door convertible just 7 days later! The car now has a mild 302, C4, 8" with disc brake front end.
    Cheers,
    Noddy
  23. garvinzoom
    garvinzoom
    Who did the build. 7 days, holy ****.
    Hmmm, just noticed it is right hand drive.
  24. Beach Hop
    Beach Hop
    We did plenty of planning and prep for the challenge. You may see in the photos the door panels weren't finished in time - about the only thing we didn't manage. The team was made up of a couple of panel beaters, school kids and local car friends.
    This is no ******** - not like certain TV Shows. Kiwis know how to make things happen - quickly!
    Noddy
  25. garvinzoom
    garvinzoom
    That is a sweet ride man. Was it your car and do you still own it?
  26. Beach Hop
    Beach Hop
    Thanks! The car was built as a promotional vehicle for a Festival I help with - www.beachhop.co.nz and given away in a prize draw for $5. The winner had never owned a cl***ic/custom car or Hot Rod before and has upgraded the Falcon with a 302/C4/8" etc. He now has the bug and recently imported a 65 GT K code and 66 GT A code convert Mustangs - and we are starting a 38 Chev pick up for him as well.
    We've done a number of cars - 27 T roadster (matt black with flames), 52 Plymouth (green with purple scallops), 57 Nash Metro (gold flake), 27 T roadster (green flake) and our latest project a 59 Poncho that will be given away at the Festival next April. Check it our here http://www.beachhop.co.nz/2008_give_away_car.htm
    Have fun!
    Noddy
  27. garvinzoom
    garvinzoom
    That Pontiac is a beaut also! Do you have any info on the healight/seatbelt/third brake light issues discussed in the article? I suppose the laws are different over there and it had to be retrofitted. I find the import/export laws on automobiles to be an interesting topic for some odd reason. THANKS again for sharing!
  28. Beach Hop
    Beach Hop
    Good point! To keep this thread OT I've answered this here
    http://www.jalopyjournal.com/forum/showthread.php?p=2339643#post2339643
    Here is my daily driver.... 302, toploader and 8". Converted to RHD.
    About to get a back 1/2 ch***is, tubs, 9 inch, 15x10 Weld Racing wheels, 6:71 blown 289 (302 Mexican block, 289 crank & rods etc, 351W heads) and "restored" back to LHD.
    Pro Street I guess... :eek:
    Noddy
  29. falconizer_62
    falconizer_62
    Thanks so much for those pics. Awesome work. Did you raise the rear tail lights up as well when you made the fins or is that just how the Aussie cars are made?I can't believe you did that in seven days! You are amazing!
    wow!
  30. munster
    munster
    from burbank
    with gas prices going up i started driving mine again.
