Where can i get a piece of rubber like this?
Discussion in 'The Hokey Ass Message Board' started by Groucho, Sep 4, 2007.
  1. I need to remake my motor mnts and need a solid, hard rubber NOT hollow as pictured.
  2. pitman
    pitman
    Groucho,
    That looks alot like the old front engine mount biscuits on a '57 chev.
    If not, you might try these guys.
    www.greenerubber.com
  3. Flatman
    Flatman
    Hockey puck? (no Don Rickles jokes here:D )
    Flatman
  4. SimonSez
    SimonSez
    Some people have posted in the past about using hockey pucks for that style of motor mount rubber. Apparently if you freeze them you can drill a hole without too much problem.
  5. Ketchup
    Ketchup
    I'd try McMaster Carr, you can chose your hardness, and I usually get the stuff I order from them overnight, even at standard shipping $.
  6. LowFat48
    LowFat48
    Boat trailer roller , one roller will make a hole bunch of them
  7. How thick?
  8. 1 3/8"
  9. Trashed & Hammered
    Trashed & Hammered
    from HR,Oregon
    I dunno where to get that thing. But I do know that your green frog at Primer was beautiful! A highlight of the show for me.My girlfriend and I saw you on a surface road when we were on the freeway headed home, We could see that paint a mile away. Oh and Congrats on the third place ribbon too! P.S. I like the pipes white.
  10. TudorJeff
    TudorJeff
    I have had good luck buying rubber and polyurethane stock like that from McMaster-Carr too. -Jeff
  11. Not sure if you can find the precise thickness you need, but you may be able to stack some neoprene rubber - cut out with a hole saw - and get to where you want to go.
    I used some 1" for rear motor mounts in my 50 Plymouth coupe, they worked fine.
    Durometer (hardness) is about the same as factory supplied motor mount rubber.
    If you go the neoprene rubber route, before you drill the center hole - usually 1/2", stick the hole sawn biscuits in the freezer overnight and have everything set up and ready to.
    If you don't freeze the neoprene and drill it at room temp you'll have a torn out and too small center hole for the drill size used.
    Whadda ya think about using UHMW? (Ultra High Molecular Weight)
    I've been running a pair on my 32 for the last 6-7 years.
    They damp vibration and work fine.
    You can cut a biscuit out of this stuff with a hole saw and drill the center hole out with a regular drill at room temp.
    UHMW is 70% stronger than Teflon and not as slick.
    Here's a pic to give you an idea of how they look.
    The aluminum load spreaders are not required, done for looks and because I thought they were needed, but after having the 455 Buick engine/trans sit on them for 7 months without marking them I'm sure a load spreader is not required.
    UHMW also comes in various thicknesses.
    The sizes in the pic are 1" for the 32 - black frame and either 3/4" or 1/2" on the bare framed 31.
    I've found as well that some re-pro rubber biscuits are harder than others.
    I believe Ch***is Research in Iowa has the hardest ones.
  12. DIRTYT
    DIRTYT
    from Warren,MI
    i used 55-57 chevy motor mounts for my Plymouth there 2" dia. by 1" thick and very hard with a 7/16 hole in the middle. there 2.99 at autozone but make sure you ask for the "big" ones cause they have small ones too that go on top of the mount.
  13. Ralph Moore
    Ralph Moore
    Check with a company called " Daystar" they make polyurethane bushings. I was converting a 1970 2wd truck to 4wd a few years ago and called them and they custom made me some bushings. Great service and not a bad price!
  14. Devin
    Devin
    from Napa, CA
    I'd say hockey puck as well.
  15. DUSTY13
    DUSTY13
    that boat trailer roller idea is pure gold
    why the hell havent i thought of that
    thanks
  16. chevy gasser51
    chevy gasser51
    speedway motors has something like that they use with there "HURST" engine mounts
  17. anyone know the dimensions of a hockey puck?
  18. Royalshifter
    Royalshifter
    Moderator
    California Industrial Rubber in Fresno has bulk rubber. There might be one in L.A.
  19. fatty mcguire
    fatty mcguire
  20. K13
    K13
    A hockey puck is 1" by 3"
  21. Von Rigg Fink
    Von Rigg Fink
    from Garage
    try these guys..Meccom Industrial products
    clinton twp. michigan
    810-463-2828
    e-mail mipco@flash.net
    last i checked this info was still good
    Big rubber and elastomeric supplier
    think it used to be called "Atlantic India Rubber Company"
  22. ItalianStallion
    ItalianStallion
    from Jersey
    Would a hockey puck be too stiff??
  23. DE SOTO
    DE SOTO
    Groucho, Those look like the aftermarket Early Ford Rubbers...
    I got a set of N.O.S. Ford ones and they were solid ... Maybe you can locate some from one of the Ford Suppliers or maybe at the swap meet in a couple weeks.
  24. Bigdaddy
    Bigdaddy
    It is solid... I used the ones from speedway for my hurst style mount... works great..
  25. HemiRambler
    HemiRambler
    Could you fill the hole?? I mean in the motor mount !!
  26. SASROD
    SASROD
    Check out the rear radius arm control bushings on a Ford Truck (twin I-beam). The bigger rubber one sure looks like it could be used as a motor mount cushion. The hole might be too big, but dont know if that would matter. It costs about $8 a kit for one side. Might be able to use the washers/cups for something too.
  27. Bluto
    Bluto
    4 cyl Volvo
    They have a stud in both ends
