Radiator overflow tank ideas needed please!
Discussion in 'The Hokey Ass Message Board' started by 1950ChevySuburban, Sep 5, 2007.
  1. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I need a tank for my '50 Suburban. Something nicer than the liquor bottle, but not modern billet.
    I was thinking of modifying an old oil filter housing to work, the metal non-full-flow kind.
    Something bigger than an Opti-Kleen bottle, has to visually fit in with my underhood stuff. (A water flask looks cool in a Jeep, not so much here)
    Any ideas?:confused:
  2. southdiver1
    southdiver1
    Depending on how you are with a torch..
    How about an old Harley Sportster peanut tank shortened to fit?
  3. terrarodder
    terrarodder
    from EASTERN PA
    I used an old Carbon tet fire extinguisher, hanging on fire wall with org. mounting bracket.
  4. southdiver1
    southdiver1
    Oh.. How about one of those new Heinekin beer little keg thingies?
  5. GassersGarage
    GassersGarage
    I have a Sapporo polished beer can.
  6. gl*** olive oil bottle in mine
  7. ww2 canteen
    backpack weed sprayer resivior.. gas tank
    thermos... stainless plaid gl*** if done right
    enema bag.hot waterbottle
    stainless/porcelian bed urinal
    large br*** howitser shell
    one gallon baked bean/olive/ salsa can from sams club
    1 foot of3- 4 inch cast iron pipe with caps and reducer to hose size
    old coffe pot
    huge coil of copper tube
    various hand pump insect sprayers
    fill resivior from a vette
    and late 50s fords
    i dunno go look in the garage ..
    all this stuff i have in mine in plain site
  8. Here's mine. WW1 Water Canteen that I've had since I was a Boy Scout.
  9. DrJ
    DrJ
    Gl*** overflows aren't allowed on most drag strips.
    I'm using a black plastic water bottle off Wife's bicycle in a window washer reservoir bottle rack off an MGB.
    A bicycle bottle rack woud be an easy bolt on too and a number of different bottles will fit in them including some small stinless coffee thermos's.
    I found that my radiator will surge and recover close to a quart from cold to hot and back to cold so don't make it too small.
    matter likes this.
  10. panheadguy
    panheadguy
    from S.E. WI
    How about one of the "Bling" water bottles.
    That will go with yer billet.
  11. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    the old fire extinguisher idea sounds best so far, I like metal construction.
  12. Sniper
    Sniper
    I'm running into the same problem. Plan on extending the upper br*** tank so it looks a bit bigger, but as a seperate chamber to be used as the overflow. Kind of like, being hid in plain sight.
  13. Belchfire8
    Belchfire8
    How about an old Moon tank?
  14. rob lee
    rob lee
    from omaha,ne
    Here is an idea,what is it ,you figure it out[​IMG]
  15. MrVoodoo
    MrVoodoo
    from L.A, Ca
    A huge flask. I have seen a flask that is about is about 12 to 18 inches tall and 1 to 2 wide that would be cool
  16. redlinetoys
    redlinetoys
    from Midwest
    I like the fire extinguisher idea. Not sure about the one specifically recommended above, but the last one I saw was all copper/br*** and had a real nice patina...
  17. hodaddyo
    hodaddyo
    how f-ed up would you be if you had coolant as bong water? ouch!
  18. flamedabone
    flamedabone
    Mine is just a bit of exhaust tubing with a pet-**** and a small puke tube.
    Oddly enough, when this pic was taken, the top bracket was broken making it crooked. Try not to look at that part....
    -Abone.
  19. swade41
    swade41
    from Buffalo,NY
    I used the coffee part of a three part aluminum kitchen canister set, the others say sugar and tea, bought the set for 5 bucks at a flea market
  20. lincolnlog
    lincolnlog
    from Arizona
    I am not sure that I understand. why not just let it drip on the ground? I mean, aside from all the environmentalists whining. How does it make it's way back into the rad?
    maybe i don't get it cause my flathead has a reservoir on top of the radiator.
  21. you need a radiator cap(usally with out the ears ) that lets the pressure out then draws the fluid back in when cooled... it make the system airless thus the boiling point rises too... the draw back is most old rads are not ready for thr 15-20 lbs of presseure to do this ...if its just a catch can then it stays out when puked out..
    SQUIRREL DID I GET IT RIGHT OR DO I NEED TO GO STAY A NITE AT THE HOLIDAY INN?
  22. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    That bong's pretty clever............
    That coffee can looks about perfect in there!
    Good ideas going on here! I look around my shop, don't see anything just right yet.
  23. run the hose into a sealed container inside the fender area.. no one needs to see it at all there
  24. beetlejuice55
    beetlejuice55
    i like the bong idea best. or, how about one of those hooka pipes that all the gas stations are selling now ? since alot of gas stations are owned /ran by foreign people (you know the ones i'm talking about) these days...hooka pipes are available at almost every gas station here.
  25. hotrodmatt
    hotrodmatt
    Old fire extinguishers...
  26. 22dodge
    22dodge
    from Nevada
    I used an old oil puke tank from a sprint car.
    Welded a bung to the top where the K&N breather went.
    Inlet has a tube that runs to the bottom of the can.
    It should work out OK. Old aluminum part, recycled ;)
      63.6 KB
  27. hardmeat
    hardmeat
    from omaha
    thats the coolest overflow
  28. nexxussian
    nexxussian
    So, the tape plugs up the carb?
  29. tommythecat79
    tommythecat79
    I just bid on a ol' timey looking embaulming fluid bottle with a bunch of lettering on it still has the label too that is kind of cool it says how much to use to give the corpse a soft velvety apperance.
  30. Brad54
    Brad54
    from Atl Ga
    Get one of the Budweiser 16-oz aluminum beer bottles, strip the paint off with EZOff oven cleaner, and then wrap a pad of 0000 steel wool around it and twist--instant spun aluminum beer bottle.
    I'm going to mount mine upside down, with the neck at the bottom, a disc welded across the hole, and a radiator drain pet**** installed. Then drill a hole through what was the bottom of the bottle, but is now the top, and insert a length of aluminum line all the way down to the bottom of the bottle, so it'll be a recovery tank, rather than simply overflow.
    Tig a simple mounting bracket to the side, and call it done.
    -Brad
