Master cylinder choice
Discussion in 'The Hokey Ass Message Board' started by Michael Pukash, Sep 6, 2007.
  1. Michael Pukash
    Michael Pukash
    My old rod has 66 bronco rear brake drums and 48 ford fronts. the master cylinder will be mounted on the firewall for all to see. Whats a good choice that will look early 60's and still be safe and do the job.
  2. HemiRambler
    HemiRambler
    60's chevy truck - "Dual Bore" master cylinder . This is the brake/clutch m/c - and can be used so that both bores work the brakes. Easy to make a "balance bar" system out of it as well. They work great BTW - although may take a little fiddling to get the balance right.
  3. 37RAT
    37RAT
    from Wisconsin
    <TABLE id=HB_Mail_Container height="100&#37;" cellSpacing=0 cellPadding=0 width="100%" border=0 UNSELECTABLE="on"><TBODY><TR height="100%" UNSELECTABLE="on" width="100%"><TD id=HB_Focus_Element vAlign=top width="100%" background="" height=250 UNSELECTABLE="off">Just for your info., chevys bore size is 1 1/8 inch, international truck that looks very similar to chevys dual bore is 1". Keep this in mind if your wondering about having enough brake pressure at the wheel cylinders and your pedal travel. I like to stick with 1" bore if possible when running manual drum brakes.
    </TD></TR><TR UNSELECTABLE="on" hb_tag="1"><TD style="FONT-SIZE: 1pt" height=1 UNSELECTABLE="on">
    </TD></TR></TBODY></TABLE>
  4. Rodderdave
    Rodderdave
    from CT
    How about a 67 mustang master.I think that was the first year for a split system and its 40 years old!!
  5. Rodderdave
    Rodderdave
    from CT
    One more thing, look for a master with the ports pointing away from the engine. They always seem to be in the wrong place.
  6. Michael Pukash
    Michael Pukash
    Thanks for the info guys!
