vacuum advance carburetor vs. mechanical advance carburetor
Discussion in 'The Hokey Ass Message Board' started by MrVoodoo, Sep 10, 2007.
  1. MrVoodoo
    MrVoodoo
    from L.A, Ca
    vacuum advance carburetor vs. mechanical advance carburetor explain the difference and why do 700R's need a vacuum advance. Or so I was Told. I was told I need to use a vacuum advance carb when installing a 700 in my 51 or change the valve body to make a manual shift?? I do not get that. Sorry if this sounds dumb, have never done a trans swap.
  2. Rich Rogers
    Rich Rogers
    do you mean vacuum or mechanical secondaries? If so I don't know what that would have to do with the 700R.The older turbo 350 needed vacuum to the modulater valve for proper shift point but I guess this question kinda puzzles me too.Advance compared to mechanical only determines the rate that the secondaries on the carb open.Mechanical meaning right now verses vacuum pulling them open more gradually.
  3. MrVoodoo
    MrVoodoo
    from L.A, Ca
    yes secondaries
  4. i see no reason why the carburetor would make any difference. just make sure you hook up and properly adjust the TV cable
    i suggest you read about 700R4's on this website:
    http://www.bowtieoverdrives.com/index.shtml
  5. MrVoodoo
    MrVoodoo
    from L.A, Ca
    Those are the people I have bought my stuff from and told me about the vacuum with the 700r.
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    That makes no sense. Vacuum or mechanical, it's a matter of tuning and choosing a carburetor that's well suited to the rest of the engine, as well as rear end ratio.
    Elcohaulic likes this.
  7. heycad
    heycad
    from Kansas
    need a vacuum switch for 200 700 trans!!
  8. dirt t
    dirt t
    Ported vacuum ?
  9. 57 Fargo
    57 Fargo
    I’m hoping he has figured it out in the last twelve years
    Old wolf, egads and scotty t like this.
  10. Fordors
    Fordors
    Actually there is a need for a vacuum switch with some installations of a 700R4 when adapted to a vehicle with no computer to control lockup converter function.
    I had an ‘82 GMC with a 305/700R4
    and the lockup worked differently than the automobile transmissions. There was a firewall mounted “low vacuum switch” and it was wired into the trans/converter to disengage the lockup when the truck was climbing a grade, or in any other low vacuum condition so the vehicle wouldn’t labor against the lockup.
    scrap metal 48 likes this.
  11. Fordors
    Fordors
    I can ***ure you GM had a reason for using that, they don’t spend money needlessly.
    The purpose of the vacuum switch was to release the lockup, not engage it. When the throttle was depressed as in going up a hill engine vacuum drops and cuts the lockup circuit. With the trans in OD the converter would be locked up, no slippage to help fuel economy and it also helps prevent overheating the trans fluid. By taking it out of lockup the vehicle has an easier time climbing a grade, or p***ing another car. The slippage in the converter allows the engine to rev into the power band easier, the same reason a higher stall is used for added performance.
  12. Fordors
    Fordors
    Why would GM have used a manual toggle when the function could be performed seamlessly, without driver interaction?
  13. deucendude
    deucendude
    from norcal
    Keep it simple. Pressure switch and correct t.v. cable geometry. At least that's what I call it.
