anybody know what has the same front drum as a 55 chevy
Discussion in 'The Hokey Ass Message Board' started by i drive 55, Sep 11, 2007.
  1. i drive 55
    i drive 55
    so i was replaceing lug studs on the front of my 55 chevy 210 wagon and ended up bending the drum. All the junkyards around me are pretty modern with thier oldest complete cars being late 60's early 70's. The question is is there anything newer i could get the drum from at a junkyard with out 50's chevys in it? I actully know a guy that probably has one but it would definatly be cheaper from the salvageyard. thank you
    COLE
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I'm pretty sure it's got to be '51-'58 Chevrolet.
  3. Squablow
    Squablow
    If 51-58 really is the same, I'm parting out a '52 wagon and I could come up with a pair of fronts. Let me know.
  4. i drive 55
    i drive 55
    thanks for the help guys.
    cole
  5. FritzJr
    FritzJr
    Corvette through 1962 or through 1964 for rear only. But looking for Vette parts won't make it cheaper or easier.
  6. sufoowt
    sufoowt
    Advance auto lists the same drum #s for 55 to early 70's fullsize Chevys. Try a search on Autozone or Advance Auto and see what will interchange
    Fred
  7. squirrel
    yup, same drums used on full size cars out back till 70.
    so, you're looking for 51-58 front, 51-70 rear, for full size Chevy cars, make sure they're 11x2"
  8. Mike
    Mike
    While you've got all that apart, you might consider switching to the '61-'72 front hubs and bearings. This will ditch the ****py, stock ball bearings and give you roller bearings. I did this on my '57 Sedan Delivery, it's a bolt on deal and all the parts for the conversion (hubs, bearings, races, etc) cost less than the stock ball bearings and races alone.
  9. xtralow 60
    xtralow 60
    from houston
    I have the hubs and drums to upgrade to roller bearings if you're interested.
  10. 40StudeDude
    40StudeDude
    Try NAPA...they still stock new...
    R-
  11. old dirt tracker
    old dirt tracker
    from phoenix
    front and rear the same 51-56 in my hollander interchange. doest go any newer. but some were along the way the fronts got wider. i thought that was 58 but would not swere to it.
