which radiator to use in my AD truck?
Discussion in 'The Hokey Ass Message Board' started by Revhead, Sep 11, 2007.
  1. Revhead
    Revhead
    from Dallas, TX
    I have two radiators.. one I am pretty sure is a 1/2 ton '50 model and the other I'm not sure about.
    The one I am not sure about has the thing with the tube on it... is that some sort of purge valve?
    The panel truck will be getting a 400 SBC. will either of these radiators be sufficient? if not who makes one? or what else fits?
    I know a 400 SBC is not traditional, but this whole truck is being built out of leftovers and so after offering a 351c I had for trade, a 400 is what I was offered and that is what I'll use.
  2. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I would have a 4 row radiator made to fit. You get more efficient core design, and new non-brittle metal.
    Just one of those things you can't skimp on.
    remember, a 400 SBC has siamesed cylinders, no water between them.
    Any good local shop should be able to make you one. If they have to, your old tanks may suffice. And the side brackets too.
  3. Revhead
    Revhead
    from Dallas, TX
    Yeah I had my doubts about using either of these when the engine itself needs all the cooling help it can get. If they will use my tanks, which set should I use? I'm still not positive what the purpose of the valve(?) is on the second rad.
  4. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I'm not sure either, it looks pressure activated, like an early overflow device before they did it thru the cap.
    Let the metallurgy decide which to use. Least rotten, use that one!
  5. Byron Crump
    Byron Crump
    I have a 400 in the merc...I have had several and 400 chevy's always seem to run hotter than 350's. Your gonna want all the radiator you can for it. Funny thing is all my 400 Pontiacs never did this to me, but the chevs without fail would give me fits. That 409 I had did the same thing.
  6. old dirt tracker
    old dirt tracker
    from phoenix
    you want all the radiator you can get for a sbc400. this is not a place to go cheap. a good radiator is insurance. i see people all the time with a $2000 motor and a $100 radiator.
  7. 51 pickem up
    51 pickem up
    from mosheim,tn
    i have a 350 in my 51 and i got a dessert cooler from chevy duty/w trans lines for about 400.00.
