want to lower my chevy...
Discussion in 'The Hokey Ass Message Board' started by Taff, Sep 10, 2007.
  1. Taff
    Taff
    ...and I'm after a little help
    First off, apologies for probably going over old ground for some of you, but I'm keen to get it right.
    so, a couple of questions
    1/ if I chop a coil, how much will it lower my '49 sedan?
    2/ How many coils can you cut out safely?
    3/ does anyone know if these:-
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=200148802912&fromMakeTrack=true
    will fit a the '49 chevy as he clims they might? I have looked thru the Fatman site, and it doesn't give an indication either way.
    Thanks in advance
    Taff
  2. slow64
    slow64
    from MB, Canada
    1/ depends on how sagged your coil is, what you're running for an engine, etc. Most people cut between 1 and 2 coils. Avg is probably 1-2 inches depending.
    2/ none? Keep your A-arms parallel. Best to sneak up on it. Start with one, re***emble, measure, repeat if necessary. Don't cut more than 2. make sure that you cut the spring at such an angle that it will seat properly.
    3/ I don't know. Never seen Fatman stuff before but those look scary to me. But hell, what do I know.
  3. JMaurice
    JMaurice
    from Kustomland
    ***uming your springs are in good shape, I agree - start with 1 coil and go from there. These springs are on the small side and don't have as many coils as later models, so they tend to go down quickly when you start cutting. Also, I would strongly suggest using a cutoff wheel! Torches can bend and overheat springs... not good.
    Of course, a dropped spindle is the right way to go. They keep the geometry of the front end the way it was designed by only raising the wheel. When you cut springs you raise the wheel and the a-arms.
    Hope that helps!
    -John
  4. lrs30
    lrs30
    from Kentucky
  5. Taff
    Taff
    thanks for that, guy's
    on another thread I saw, someone mentioned simply (?) flipping the uprights. anyone ever tried this?
  6. slow64
    slow64
    from MB, Canada
    I'm not sure how you'd do that. Stocker is on the right. Ends look different to me.
  7. BZNSRAT
    BZNSRAT
    Yes a few of the golden rules...1 coil at a time and NO heat!
