any blown y blocks ?
Discussion in 'The Hokey Ass Message Board' started by wyoming, Sep 13, 2007.
  1. wyoming
    wyoming
    from My house
    any one out there running a blown y block or ran one in the past ?
  2. photofink
    photofink
    I have a Y-block with a blown head gasket.
  3. FalconEddie1964
    FalconEddie1964
    I blew up a bunch of them when I was a kid.
  4. flatoz
    flatoz
    theres a roadster here in Australia with a blown (3/71) Y block, been on the streets for years, not sure on the boost or anything.
  5. flatoz
    flatoz
    if you check out brootals webpage there will be a photo of it
  6. telecaster_6
    telecaster_6
    Depends on what kind of supercharger your talking about. There were the factory t-bird centrifugal (paxton) supercharged y-blocks, not plentiful by any means, but they are still out there. I've seen a few...and i mean FEW roots style supercharged y-blocks, usually 6-71 units. If you were really interested in supercharging one, I would contact John Mummert out in Cali...
  7. nexxussian
    nexxussian
    I remember reading somewhere, on the web (not here) about a guy that had a set of adapter plates machined up to fit a SBC 471 blower manifold to a Y block. I was searching for multi carb manifolds for Y blocks. It probably wasn't the prettiest flow path, but it was a street deal. Under boost I would expect it to be less critical in anything but a compe***ion environment.
    Hope that helps.
  8. Sixcarb
    Sixcarb
    from North NJ
    292 with Cragar drive and manifold.......
  9. I had a 1957 f-series 312 with a factory supercharger back in '62 It would run! 4 speed, 4.57's in a Fairlane 300 it carried an under rated 300 horse factory rating.
    I've always considered blown as a roots style or the back of a blonds head in my lap (sorry for the OT)
  10. ynottayblock
    ynottayblock
    oh my, i have to go change my underwear
  11. Late
    Late
    from Finland
    Heres mine projectmotor 239 and 4/71. Someday im gonna start to rebuilt it, but first i had to do mine ´54 Ford. [​IMG]
  12. wyoming
    wyoming
    from My house
    so i take it that y block blower manifolds are few and far between
  13. devilscustom
    devilscustom
    from Sweden
    cool 239 i gonna soon start my y-block blower projekt a 292 bored 0.60 with a 239 crank it gonna be a 280 cui :) with old iskycam and mallory ignition ,4-71 ánd 2x4
  14. There were only two blower intakes ever made by the aftermarket (excluding the Latham ones & the BT intake for the Paxton centrifugals)...Cragar made a 3-71 & a 4-71 intake. I have never seen a 3-71 version for sale (or even NOT for sale), & the 4-71s go for stupid money when they do show up every great once in a while.
    It would be fairly easy to fab up a top plate for a conventional four barrel intake to mount a 4-71, then get the appropriate drive parts.
    So far as the SBC intake goes, look here: http://www.jalopyjournal.com/forum/showthread.php?t=200246
  15. converseandbowlingshirts
    from Eugene, OR
  16. mtkawboy
    mtkawboy
    I had a friend whos gone now who raced 57 Fords on the beach at Daytona. He told me that the factory cars were the only ones who ran blower cars because they had special German made bearings in them. The factory stock bearings would sieze up in the long races so everyone ran the dual quad setup. They built their car in Miami and drove to Daytona to break it in just the way they raced it with open exhausts
  17. wyoming
    wyoming
    from My house
    so youre saying make a plate that just mounts to the 4 bolts on the stock intake ?
  18. Sixcarb
    Sixcarb
    from North NJ
    Yes you can make a plate off a 4 barrel intake or any y block manifold it just depends how far you want to go on fab work, when making your plate and aligning from front to back make sure you have your pulley and drive setup complete so you can line everything up properly, the only other thing to keep in mind is some type of pop out valve on the intake so if the blower pops back you don't split something apart, BDS makes different shape pop outs which you may be able to incorprate into a four barrel manifold, try and find one that may have a flat surface somewhere that you can drill into the plenium.
  19. T-BIRDMAN
    T-BIRDMAN
    This is my first posting. I am running a 292 with a compe***ion Latham in a two-seater T'Bird. Running all the original Latham components (Mallory, Carter YH, linkage, etc. Right, the Latham did have a (very) special intake for use in T'Birds; they were hand made from flat stock to avoid cutting the hood. The first adaptations of the axial flow to T'Birds required a rather ugly hood scoop extension that certainly cost them several sales.
    Regarding the use of German bearings in blowers at Daytona, these were probably for the VS57 (variable speed) versions. The factory blowers were VR57 (variable ratio) and a whole lot more reliable.
    devilscustom: for a good 292, use the 3.1 shaft with a 3.875 bore. A good friend did this and was an AHRA
  20. SCHWINNNNNNGGG!!!
  21. Hey SIXCARB. That's what I like about hot rods. It's not copy cat and it is bad ***. You have the engine compartment looking perfect. That thing is the shizzzzzz and those headersrule>>>>.
  22. Skankin' Rat Fink
    Skankin' Rat Fink
    from NYC
    That thing must sound absolutely incredible.
