model a help please
Discussion in 'The Hokey Ass Message Board' started by SATANSSHO4, Sep 17, 2007.
  1. SATANSSHO4
    SATANSSHO4
    ..NEW PICS AND VIDEO... I picked up a 31 coupe body in a junk yard cheap last year.I had it blasted and put away until now.i purchased all the patch panels and sub rails i now have it channeled and some of the panels cut out. at first i didnt realize that some one had cut the lip that the hood sides rest against all off. so now i need full cowl panels and they are not available could some one tell me please what is the difference in width from a roadster or what is the width of a roadster cowl as i want to make them fit. thank you to all that can reply heres pics of car[​IMG][/url][/IMG]
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Bummer, the cowl panels themselves should fit from any body. That's the one part of the car that is samey same.
  3. SATANSSHO4
    SATANSSHO4
    another before channel[​IMG][/url][/IMG]
  4. jetmek
    jetmek
    i think brookville can supply roadster cowl sides. its only different at the toprear part. if you get hard up, ive got one that the windsheild posts were cut off....
  5. dodgerodder
    dodgerodder
    I had a similar question a while back, and some fellow hamber's came to my rescue. Here is a link from that thread that should give you some helpful info:
    http://www.jalopyjournal.com/forum/showthread.php?t=110057
    The roadster beltline is different, but the rest is the same. For what you need to do, they should work. The roadster full cowl panels are a little spendy, but it is what it is.
    Hope this helps a little
    Dan
  6. SATANSSHO4
    SATANSSHO4
    thats what i was wondering so the roadster is the same width but has a different reveal at top?
  7. SATANSSHO4
    SATANSSHO4
    thanks for the link dan just the awnser i needed
  8. jetmek
    jetmek
    yeah where the w/s stanchion bolts on at the top rear
  9. dodgerodder
    dodgerodder
    No problem man. I've had others help me so many times here, glad I could return the favor.
    The first 3 pics in my attached thread are a closed car cowl, & the bottom pic is a roadster cowl. You can see the difference of the beltlines between the two. The closed car beltline has 2 beltlines-the thin lower beltline is seperate from the beltline that is under the windshield posts.
    The roadster does not have the thin beltline at all
    But dimensionally they are the same though. Kind of hard to explain, but easy to see looking at the pictures
  10. 1930 ratrod
    1930 ratrod
    from colorado
    satanssho4 do you have any new pics of the model a its looking kick ***!!!
  11. SATANSSHO4
    SATANSSHO4
    ill get some together as i found in junkyard to present state
  12. SATANSSHO4
    SATANSSHO4
    more progress, new well not really new cowl panels[​IMG][/IMG]
  13. SATANSSHO4
    SATANSSHO4
  14. SATANSSHO4
    SATANSSHO4
  15. SATANSSHO4
    SATANSSHO4
  16. SATANSSHO4
    SATANSSHO4
  17. SATANSSHO4
    SATANSSHO4
  18. SATANSSHO4
    SATANSSHO4
    things that have been done since last pics and thanks for all the info from other board members. channeled the body 4", zed brookville frame 8", replaced all bottom patch panels, new cowls from carisle swap meet , new subrails that i cut away most of what i bought to channel the body (snyders) new cowl top swap meet, redrilled 55 chevy axle to fit 4.5 bolt circle will have new pics soon
  19. SATANSSHO4
    SATANSSHO4
    Well the weather was nice in Philly today.T-shirts in february?Global warming I guess.Since the sun was out I figured I would let the coupe see daylight again,Its been a year and a half since I put it in the garage to work on it. The winter has let me get alot done.Finished the metal work on the floor,ALOT of bodywork,atleast its straight now.Tore all the wood out and replaced it.Painted the floors,firewall,steering and suspension white,And the motor and trans cinder red.Put some 180# coilovers in,Cut in some taillights and drilled the visor to match the axle. Now that I got it outside I got all excited and wanted to hear it make some noise.I started robbing parts off my 55,Stole the carb started making a gastank out of a milk jug(real safe I know) found a junk fuel pump on the shelf,made a ignition switch setup with some wire.And then I borrowed the battery out of my dads 37. JUst as I suspected it was LOUD :D BIG thanks to my father for doing the honors so I could arm myself with the fire exstinguiser and camera.
  20. SATANSSHO4
    SATANSSHO4
  21. SATANSSHO4
    SATANSSHO4
  22. SATANSSHO4
    SATANSSHO4
  23. SATANSSHO4
    SATANSSHO4
  24. SATANSSHO4
    SATANSSHO4
  25. SATANSSHO4
    SATANSSHO4
  26. moon man
    moon man
  27. thunderbirdesq
    thunderbirdesq
    Looks great so far! Nice 60's drag style...
  28. SATANSSHO4
    SATANSSHO4
  29. I SMELL SMOKE
    I SMELL SMOKE
    looks good and sounds good too!!!!
  30. Big Tony
    Big Tony
    Nicely done and the motor sounds freaking killer
