Updated HAMBANDY build list...Aug22
Discussion in 'The Hokey Ass Message Board' started by movingviolation, Aug 22, 2007.
  1. movingviolation
    movingviolation
    Hey everyone,
    I was asked by some of you to get a new thread going that was not so long winded. So here is the list and i will add to it the parts still needed.
    So here we go.................................... with the already offered goodies.
    Doc. for the wonderful model a that Andy is now the proud owner of.
    And this could not happen with out some of Andys new friends who has kicked in to get this to happen.
    Shane T* Brookville dash/gauge
    OldCarmike* Will sew the seats
    OLDBEET* Gl***
    wannaB* Materials for seats
    Chuck Speed* Gauges
    Barz51* the 94's
    PRIMERDAVE* early kh wires
    hot rod artist* rebuild and set up carbs on intake
    Jrblack30* offy superdual and cleaners
    DrDano* rebuild any electrics
    Crestliner* flathead headers
    ****ster27* wire harness carb parts 39 lenses/gaskets
    Tim Brown* altenator and flattie adaptor
    atch*dropped axle
    raven61*posie spring
    t-bone*39 tail lites
    LUX-BLUE*hood (Andy wants to be able to have the option)
    kwiksilver*column/wheel/arms/lites
    G V Gordon*fuelblock
    Kustomman#1*head lite stands
    53chevy*peeps and kh caps
    Dougan*steel 32 grill shell
    Deano*banner for the dash signatures
    Brokenspoke*shockmounts
    Rodsnhawgs*pete and jakes front shocks
    Bulletnose*plugwires e-brake lever and gas pedal
    shifty-shifterton*front spring and rear hanger.
    Areo46chevy*black satin paint
    Kiwi Kev*sweep tach
    53Chev*so cal ignition and ***orted stuff
    raven61*master cylinder
    hot rod artist*chrome fuel reg and header gaskets
    harrison*kingpins and stops
    Please keep your fingers crossed for Andy. He is USA bound for surgury this Saturday.
  2. Harrison
    Harrison
    What does he still need?
    JH
  3. kwiksilver
    kwiksilver
    My end left today headed towards Andy!!
  4. movingviolation
    movingviolation
    A old sweep style Tach
    Dizzy for the flat head.
    Rad overflow tank...
    Heads
    Beehive oil filter
    Insert for 32 shell
    Switches and ignition with keys
    etc, etc,etc
  5. movingviolation
    movingviolation
    Aero46chevy from Canadianrodder is in for the paint!!
  6. PM me an address where to send a tach, I just got one at a yard sale. Now it's Andy's!
  7. 53chevy
    53chevy
    I've been slackin. I got the stuff together and will ship them out Monday morning with other stuff that might be needed. Can't wait to see the finished Hot Rod! Get Em' Andy!!!!!!!!!
    Ken
  8. 53chevy
    53chevy
    Hey! I have a SoCal ignition switch and key, brand new and never used, I'll throw that in there too!
    Ken
  9. fitzee
    fitzee
    OK guys I sat down and made a list of parts that will be need for the build.We are still doing our homework on a gearbox and not sure which way to go_Other then that we have nailed down a list of parts.
    Front spindles (Ford)
    King pin hardware
    Shackles to mount front spring
    front spring perches (Spring over)
    front flex lines
    front brake parts(drums,backing plates,shoes,etc)
    Tie rods for drag link
    mufflers
    gear box parts??
    drive shaft parts (yoke to gearbox)??
    transmission mount??
    Shackles to mount rear spring
    Rear spring mounting brackets
    rear shocks
    Rear shock mounts
    gas tank
    master cylinder
    hand brake
    brake fittings
    lug nuts
    9 inch ford rear end parts (drums, brakes etc)
    rear radius rods or ladder bars
    Flattie parts
    • Carb linkage
    • oil filter
    • plugs
    • Radiator
    • Radiator hoses
    • Header flange gaskets
    • distributor
    • intake gaskets
    • clutch/pressure plate
    • fuel line
    If you feel I over looked anything please let me know.
    fitzee
  10. movingviolation
    movingviolation
    I believe the carb linkage is already on the intake/carb set up.
    Thanks for the list Fitz
  11. panhead_pete
    panhead_pete
    I cant really add parts from down here but I can send some posters for upcoming shows down here in Perth. Is this something that he might like on his wall? If so someone PM me an address ans I'll send them.
  12. raven
    raven
    I have a brand new master cylinder that you can have.
    r
  13. Casey
    Casey
    could not find the other end of the linkage I took off my coupe ?
    Im shure it will show up after the new linkage from speedway gets here :eek: will send the set up next week! :) I do not have a intake gasket . but I did find a nice crome fuel pressure regulator I will throw in, you only want 2-3 psi.
    and I have the header gaskets ,they will be in the box.
  14. movingviolation
    movingviolation
    Update from Chris.....................
    Hi Everybody, we are in the hotel. Long trip for Andy. We controlled the
    pain with Morphine and he did good. So I guess its on to the next step.
    Testing starts on Monday at 7:45 and it will be for the whole day. He will
    rest tommorrow.I will keep you posted. Thanks Chris
    Keep your fingers crossed and your thoughts with Andy, he has a big *** fight on his hands. Time to kick the **** out of this tumor once and for all.
    Leon
  15. Church
    Church
    from South Bay
    Not sure if anyone saw it, but there is a small write up in the new Rod and Kulture mag about the HAMB lending a helping hand for Andy. Way cool.
  16. dickster27
    dickster27
    from Texas
    Stay positive Andy cause you have one hell of a bunch of great folks watchin' your back. Good luck with the tests Little Buddy.
  17. movingviolation
    movingviolation
    Thanks to everyone who sent parts to the H.A.M.B drags, and as well to every one who signed the dash.
    Watch for Andys updates.......tests began today, surgury in few days. As well the model a should be here for Friday.
    Leon
  18. Casey
    Casey
    Got the linkage on today I think Im done now what do I do with it ?
    it look`s fast !.....
  19. movingviolation
    movingviolation
    You have a pm.
    HArrison is in for the kings and stops.
    More wonderful parts arrived today and parts from joplin will certainly make this project awsome....especially the signed dash, your personal touch will add character and remind all who see it how fuk'n great hot rodders really are.
    Leon
  20. fitzee
    fitzee
    Sweeeeeeet!! that set up will make Andy`s day. Leon has been showing me the parts as they show up and I must say old parts down there and nothing like the stuff I`m use to. Leon showed up today with a pic of the dash so I had to post it on the wall in the shop for all to see. You guys Rock!
    fitzee
  21. kwiksilver
    kwiksilver
    Have you seen the stuff I sent yet...I hope?
  22. fitzee
    fitzee
    Yes showed up a few days ago.Great stuff and in great shape.The box is nice peice.Oh cool drawing of hambandy on the box.lol
  23. Hackerbilt
    Hackerbilt
    Hey guys...
    I have the front axle here at my place now to dis***emble, then re***emble to the dropped unit once it arrives.
    We're short a couple of items....figured I'd ask again if someone has them to donate before we order the parts from Speedway. (Trying to keep out of the Hambandy fund if at all possible!)
    1) We're short a set of perch bolts to hang the spring from on the dropped axle.
    2) A set of front shackles and bushings to fit the front spring. (I'll ask Fitzee to measure the bushing Diameter and spring width just to be absolutely sure on that stuff.)
    3) A set of perch bolt shockmounts would save some fabrication as well...but if not we'll make something up ourselves.
    I'd personally like to thank you guys for sending some GREAT stuff up to Andy for this build.
    I finally had a chance to look at some of the parts...just incredible what you guys have sent already!
    Andy is gonna have one cool little Tudor!!!
    Anyways...the build will go on with or without donated bolts etc...just figured I'd ask in case someone had a set they're tripping over or what not...
    Thanks guys! ;)
  24. 16grem72
    16grem72
    Are there any pics of Hambandy's sedan build yet. Just a thought maybe start a build thread. Ive been trying to keep up with it all but always seem a couple steps behind. Im pullin for ya Andy.
  25. elcornus
    elcornus
    I'm building the coulmn drop as we speak. It has an 1 3/4" Dia. coulmn hole, and if it needs to be bigger, I need to know the size ASAP!!!!!!
    I'm about to do a machineing operation that will make enlarging the coulmn hole VERY difficult to do after the operation is done.
    Please get back to me ASAP at (805) 234-6756.
    Eric
  26. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    I'll chip in insulation if its needed.
  27. movingviolation
    movingviolation
    Just spoke with Eric................ Man, hot rodders are awsome! Andy will be super stoked when he sees that drop!
    And Lobucrob, that insulation would be awsome.
    Leon
  28. HotRodChassis
    HotRodChassis
    Alliance Vendor
    I may be too late, but has anyone donated ***embling the ch***is? If all the parts are there, I've got a jig table and a tig welder just waiting for it all.
  29. Big Dan
    Big Dan
    Hey Leon.... Just checkin if those smithy mufflers got there... I see mufflers still on the list, so you might want to upgrade the list so no one else sends a set.......... Big Dan
  30. movingviolation
    movingviolation
    Hey Dan
    Thanks so much...............those smithys arrived Thursday.
    Leon
