Desoto Hemi Valves -- SS exh. valve?
Discussion in 'The Hokey Ass Message Board' started by joeelutz, Sep 11, 2007.
  1. joeelutz
    joeelutz
    OK, I pulled heads and the cam from my 330 FireFlite last night. I'm planning to send the cam off to Clay Smith for a regrind. George at Clay Smith Cams recommended that I also switch to SS valves, so out of curiousity I pulled an intake and an exhaust valve from one of the heads. I thought they were the stock valves. Interestingly a magnet will stick to the intake valve, but not the exhaust valve.
    So the question is: Did the DeSoto's come with SS exhaust valves from the factory?
    Thanks
  2. MR. FORD
    MR. FORD
    from Austin, TX
    Somebody help this guy! DeSoto where are you?
  3. Id like to know as well !!.....
    Rat
  4. joeelutz
    joeelutz
    ttt still unanswered
  5. JaBoney
    JaBoney
    Me too! I got a 56 330 Desoto engine and would like to know:(
  6. DE SOTO
    DE SOTO
    I went thru 5 sets of 330 heads to find 1 pair of uncracked heads & never saw a s/s valve in the bunch.
    I would assume that they were installed AFTER the fact for whatever reason.
    But it is a Chrysler product so ya just never know.
    I have seen 1 set of Chrysler 331 heads that had S/S valves in the exhaust, but cant prove if they are stock or not.
    I WOULD SAY NOT.. BUT I HAVE BEEN WRONG BEFORE :D
    I bought my S/S valves from a place called HD MADDOGG RACING, They sell stuff all the time on E~BAY and they were almost 1/2 the cost of HEMI HOT HEADS.
    I took them to my machine shop, WILLIAMS MACHINE IN VENTURA.. Yes, The same WILLIAMS MACHINE that owned the now famous BARN FIND :)rolleyes:) WILLIAMS BROS 1955 BONNIVILLE ROADSTER that has been in rodders journal & this months Hot Rod.
    John at W/M said they were a quality valve.
    I run them in my now 346 cu. in. DeSoto with 11.5~1 pistons
  7. 41hemi
    41hemi
    I still have the original valves left over from my 330 DeSoto rebuild so I went out to the garage and checked them with a magnet (intake and exhaust). Both sets are regular steel. BTW, when I redid the heads I used Chevy 1.94 SS valves; just made up guides that would accept the smaller diameter valve stem; all the other dimentions were the same!!
  8. joeelutz
    joeelutz
    Great info people! Thank you very much!!
    DeSoto, How many grooves do your SS valves have for the retainer locks?
