My 1925 Chev Roadster after a Molasses Bath
Discussion in 'The Hokey Ass Message Board' started by Jimmy B, Nov 12, 2006.
  1. Before
    After
  2. famous59
    famous59
    from dallas, tx
    damn that came out good. I have a 27 T that needs to be done. How long did the process take and what was all involved ? details if you can
  3. Gerg
    Gerg
    Damn i was skeptical of that before that looks pretty damn clean!
  4. tmf
    tmf
    Looking good Jimmy. Keep at it.
  5. Mad-Lad
    Mad-Lad
    WOW!
    That came out nice. give us some details......
  6. TxRat
    TxRat
    yes please. more details
  7. Bugman
    Bugman
    Geez...how much mol***es and how big a tank did that require:eek:
  8. Hell yeah, I was thinking the same thing. Or can you apply it like stripper and let it set on the surface.
    Sure does clean the metal nice.
  9. arkiehotrods
    arkiehotrods
    Papa Mole, Mama Mole, and Baby Mole were following each other through the mole tunnel. Papa Mole stops and sniffs the air: "I smell turnips." They go a bit further and Mama Mole stops and sniffs the air: "I smell turnips, too." They go a little bit further and Baby Mole stops and sniffs the air: "That's odd, all I can smell is mol***es."
  10. X38
    X38
    I use 5:1. When I did my 40 dash, I made a temporary trough with a basic wood frame and lined it with some plastic sheet. Was only deep enough to keep the dash under the liquid. Covered it with some board and left it a week, gave it a scrub, left it another week and what was the colour of Jimmy B's firewall came out spankin' new! I treat things with a metal prep solution straight away to prevent the almost instant flash rust. I use Ranex, Jimmy might know it.
  11. I used a 7:1 water to mol***es mix in the blue 44 gallon drum in the pics.
    The cowling I dipped in this.
    Make sure not to use black plastic, use the pond liner that you get from the hardware or landscape suppliers as it is rubber and will cop alot more abuse, also use some old rubber floor mats to protect the bottom as you don't want to cut the liner as it is not cheap cost me AUS$60.
    I left the cowling in for 10 days, usually you leave it in for 14 days.
    this is after 5 days. The surface rust wasn't as bad.
    When I was searching for info on this process I came across one guy who built a tank big enough to dunk a T roadster body :eek: Now I can't seem to find it, go figure :confused: :rolleyes:
    Cheers
    jimmy
  12. racer756
    racer756
    So ya dig big hole in the ground, line it with plastic and fill with mol***es. I bet all the critters in yer area have a lot of cavities in their teeth:D
  13. Splinter
    Splinter
    I didn't know Mole-***es worked so hard....
  14. G'day X38, where did you buy Ranex from? I just sprayed my cowling with WD40.
  15. turbostude
    turbostude
    from minnesota
    The cheapest place to get mol***es is the feed store.
  16. X38
    X38
    I get Ranex from Bunnings usualy. I think it's full name is ranex rust buster. It's phosphoric acid based, leaves a good surface, keeps rust away for a long while, especially if you can keep your hands off!
  17. Theo Douglas
    Theo Douglas
    That looks awesome! Question, though--and I'm not trying to hijack this post BUT: isn't that a Dodge front cowl? I've seen those before, and everyone always said they were Dodge. Just asking.
    Thanks,
    Theo
  18. Hi!
    Hi!
    from SoCal
    Thats a chevy cowl.
  19. Stovebolt
    Stovebolt
    I used RS-!, which I bought from the local auto paint store. My stuff came out of the tank about 12 months ago, and there's still no rust.
    You just can't beat a good bath!!
  20. wheelbarrowsgarage
    wheelbarrowsgarage
    from Missiry
    Ok, maybe this is a silly question but does the mol***es come as a liquid, errr gel, or is it some sort of pellet? Live in the midwest in the boonies but never messed with mol***es from the feed store! Looks like a good way to strip though.
  21. roddinron
    roddinron
  22. sweet Roddinrod was faster.
    Very nice job. From the looks of the before picture I would expect the body to be pitted but the after picture looks very smooth. It looks like a great start with a body that smooth.
  23. Sawracer
    Sawracer
    from socal
    Wow you could sell that service now that you have the setup! I have a banger block to dip please. :D
  24. send_it_all
    send_it_all
    Pun intended?
  25. LowFat48
    LowFat48
    Anyone know if the mol***es effects aluminum ? I have an old flat bottom boat that would make a good tank (no seats), but it would **** if the mol***es ate it up and leaked out....
  26. noboD
    noboD
    I have a Model A tank I did about 1 year ago in my shop, No oil, no primer, it hasn't RE rusted yet. Don't use a blue tarp, eats holes in minutes. Yum-Yum
  27. Mercmad
    Mercmad
    from Brisvegas
    This one? http://www.stovebolt.com/techtips/rust/rust_mol***es.htm
    Does it strip the old paint off too?
  28. Mercmad
    Mercmad
    from Brisvegas
    heres an explanation for all of this...I think;)
    Rust Removal Using - Soda Pop?
    When I was about 12 years old and just getting interested in engines I heard my uncle swear that he got a stuck piston out of a motorcycle he had by using bottle of Coke. It had set out in the yard all winter and had rusted up inside. But we all know pop is sticky, water based and wouldn't itmake a worse mess? After all, Mom always said "don't spill your pop, it will make everything sticky".
    As I grew up and got interested in cars and motorcycles myself I started to hear of other such "urban legends" and decided, hey, maybe there is something to this. The people that said it worked were quite insistant, and there sure was no proof that it did NOT work. So I decided to investigate. (amazing what little it takes to entertain me)
    So here is what I've found - many carbonated beverages will remove rust. This is because the gas used, carbon dioxide when mixed with water, makes carbonic acid. To make rust, the iron oxidizes - it combines with oxygen. This is why rust is also called iron oxide. The carbonic acid reverses this reaction - this reversal is called "reduction." Here's a better reason - take a look at your Coke can - it has phosphoric acid as an ingredient. Phosphoric acid is the basis of Naval Jelly, a commercial product used for rust removal. Phosphoric acid dissolves iron oxide very quickly while etching metallic iron very slowly so you can leave metal in phosphoric acid with little damage.
    The downside is that all acids contribute some hydrogen to the metal structure, weakening the steel by hydrogen embrittlement - so always use only as much time as is absolutely necessary to remove the rust. An advantage of phosphoric acid is that it leaves a fine protective coating of iron phosphate. Because this coating is not thick or durable some protection is still required. Years ago supposedly Volkswagon use a process of phosphating metal prior to painting as it provided a chemical protection against rust under the paint layer.
    So, spilling your Coke into your old engine wouldn't really be a bad thing if you were trying to remove some rust.
    [​IMG] to Bill's Electrolysis Page
    <address> </address><hr align="center"> All content of this site © 1997 - 2007 Bill ****erson, all rights reserved.
    Last Updated on January, 2006 by Email: <script language="JavaScript"><!-- var nam = "bill"; var dom1 = "antique" var dom2 = "-engines.com"; do***ent.write(''); do***ent.write(nam + '@' + dom1 + dom2 + ''); // --></script>bill@antique-engines.com
    http://antique-engines.com/rust-coke.htm <!--#totcnt-->
  29. Volvo544special65
    Volvo544special65
    The body looks to be in pretty good shape. Though I don't know so many english terms, what is a "Mol***es" bath?
  30. BinderRod
    BinderRod
    I thought for sure that you would have said that you applied it with a biscuit.
    Did the Bees hang around?
    Looks real good!!
