Axel ?????
Discussion in 'The Hokey Ass Message Board' started by hiboy32, Sep 30, 2007.
  1. hiboy32
    hiboy32
    from Omaha, NE
    Just wonderin what years did the "32 Heavy" axle come out? I know it is called a 32 , just wondering did come out in the 23-34 big trucks?
  2. i believe they were early 1932 p***enger cars, not trucks...those were different
  3. Harms Way
    Harms Way
    A lot of folks believe the 32 Heavy was a commercial axle only, But thats not the case, It was used on all 1932 Ford p***enger cars and pick ups, The 1933-1936 axle is the same but the 32 is all on it's own.
    Some people will probably disagree with me on this, But this is my experience backed up by research,..... however Ford did a lot of weird things.
  4. Bruce Lancaster
    Bruce Lancaster
    So far, I haven't encountered a '32 I thought was original without one or a '33 or later with one...all '32-36 interchange, but only '32 has the heavy beam.
    P***enger and commercials (pickups) got the same ones, actual trucks (long wheelbase, different frame) had axles and nearly everything else different from those.
  5. hiboy32
    hiboy32
    from Omaha, NE
    So you are saying that a 34 truck axle isnt the same? Is it still usable??
  6. Harms Way
    Harms Way
    Your right Bruce, What I should have said in my post was that the 32 was all by itself in configuration (heavy web in the end),... but you are right about there interchangeability.
    I have a question for you Bruce, the front wishbones on the longer wheelbase trucks, it seems they were heftier than the p***enger car bones,... (I have used them before,... split) But were they any longer ?
    I have a pair on my 34 coupe,... was surprised to find how heavy the wall thickness of the tube was.
  7. Bruce Lancaster
    Bruce Lancaster
    Truck stuff...hiboy, what kinda truck? Commercial/pickup, same as '34 p***enger, interchange with all '32-36...if '34 big truck, entirely different.
    Truck wishbones...I don't have any dimensions, but '32-34 big truck ones would have to be very close in length to '32 p***enger...almost identical layout back to the trans crossmember. I think this would apply to all Ford big trucks until they dropped the transverse spring later in the thirties...wishbone went back to trans crossmember, and engine/fourspeed length was same as p***enger setup.
  8. Rusty
    Rusty
    You can definalty tell the difference same width but alittle taller. I can take pics if needed
  9. hiboy32
    hiboy32
    from Omaha, NE
    I have a line on a 34 that I want to try and get parts from (just to be sure it is a 34, they had the taller body line on the back of the cab, right?). I was hoping to know what to look for before I approach them about buying the axle.
  10. SimonSez
    SimonSez
    Just to muddy the waters a bit - has anyone else heard that a 34 commercial (e.g. 1/2 ton pickup) has a different axle to the p***enger models ?
    Here's a pic of a roadster that we used to own, and you can see that the axle is a bit unusual. It's a bit hard to see in the pic, but the I-beam is taller in the centre of the axle and tapers back down to the normal 33-36 height by the time it reaches the perch bolts.
    The guy who built it is very clued up on early Fords and he told us that it was a 34 pickup axle.
  11. hiboy32
    hiboy32
    from Omaha, NE
    That axle is very cool. That is worth the trouble of getting one. I am hoping that I could get lucky on this one. I will have to look into this a little further.
  12. 3wLarry
    3wLarry
    from Owasso, Ok
    ...and all this time I thought the 'big beam' axle was installed on later 32s with the heavier V8 engine.
    kidcampbell71 likes this.
  13. Chris
    Chris
    That actually makes sense. Ford would have probably wanted to "beef" up the front end for the extra weight and power...
  14. Vroom
    Vroom
    I was actually about to start a thread about this exact same thing.
    I just bought a '34 commercial truck and was noticing that the axle was very similar to a '32 heavy.
    So what are the differences exactly? Does anyone have the dimensions for each?
  15. turdytoo
    turdytoo
    Back to the weak link story, Even though Ford beefed up the front axle in the new, bigger, more powerful '32, They milled it smaller in the area where the stress and weight were. I always ***umed Ford was trying to make it stronger with the heavy axle for both motors, '32only because of the V8 but I still guess they decided it was not worth the extra metal. Henry was frugal, you know.
  16. Harms Way
    Harms Way
    #1. 1928-31 Model A
    #2. 1932 only
    #3.1933-36
    #4. 1937 Tube (was told by Bruce these were used up to 1940)
    #5. 1937-40 I-Beam
    #6. 1941-1947
    #7. 1948
  17. 5wbomber
    5wbomber
    harms way is correct 100%, the 32 axle is however the same dimensions as the 33 to 36 axles just a LOT cooler lookin and a little thicker, people very commonly replaced the axles with 33-36 axles when something went wrong, the big trucks are not even close to the 32 heavys, bigger bosses and way bigger spindles.........32 axles rule!!
  18. pasadenahotrod
    pasadenahotrod
    from Texas
    Corrections to the above list:
    The 37-41 P***/Comm axles are the same.
    The 42-47 P*** axles do not have the shock stud mounting hole between the perch and the spindle boss like the 47-48 P*** axles.
    There is also a split on the 42-47 Comm axles which may have to do with shock stud mounting holes but I am not 100% sure.
  19. Chris P
    Chris P
    from Tucson
    Hows this?
  20. hiboy32
    hiboy32
    from Omaha, NE
    Thanks guys. I think I am armed with info I need. I will go scout it out this weekend..
  21. Harms Way
    Harms Way
    Perfect !,... except the #3 axle is 1933-1936
