Performance parts for the Rambler 327?
Discussion in 'The Hokey Ass Message Board' started by CaryW, Oct 3, 2007.
  1. CaryW
    CaryW
    from E. Tx
    The Vigilante :rolleyes: I am planning a project along the lines of some of the Willys P/U's in the other thread and I have to be different. I have a 327 mated to a TH400, but it is a 4wd transmission. Should be an easy tailshaft swap, but who knows with anything jeep, or pre jeep.
    I have a 4bbl intake. it was hard enough to find but is there anything else that doesnt have to be custom made. I know it was used in a few marine apps so there might actually be some speed parts out there.
    I would really like a multicarb intake, but have never seen one.
    Yes, I am sure it is a Rambler/Hudson/AMC engine mated to a th400 with an oddball bellhousing.
    I wonder if there is a 4speed that would bolt up instead.
  2. CaryW
    CaryW
    from E. Tx
    Whooo, tell we this is some sort of injection system
    Grays marine 250
  3. David Chandler
    David Chandler
    Some guys are using adapters like Vintage speed sells to put 2 or 3 carbs on a 4 bbl intake. You could probably weld one up from scrap. I think there was a guy from Austrailia selling some nice looking cast ones too. My limited AMC experiance was with a 64 American wagon with a flat head six. So I don't know much about their V8's. But didn't International Harvester use some of their engines?
    Good Luck.
  4. CaryW
    CaryW
    from E. Tx
    OK , I finally got my search terms right and found this thread. Seems like a good oddball to go in a oddball hotrod truck.
    I just gotta learn more about the dual carter 3559 manifold. Even though I have a 4 bbl manifold, that 2x2 looks cool, I wonder if it is marine only
    http://www.jalopyjournal.com/forum/showthread.php?t=135927
    edit I also noticed that the marine engines are listed at 9.5 to 1 comp while the AMC/Rambler stats are 8 to 1. Marine heads?
    hmmmmm
  5. CaryW
    CaryW
    from E. Tx
    Dammit, never tell the guy that is giving you a project what you are gonna do with it UNTILL you have picked up the truck.
    He wont give it to me unless it is going to be a full restoration back to original 4x4.
    Oh well, off to look at the 53 GMC and the 59 Caddy.
