Pic Request: '57 Chev w/ '57 Buick Grill
Discussion in 'The Hokey Ass Message Board' started by NoSurf, Oct 3, 2007.
  1. NoSurf
    NoSurf
    Anybody have some pics of some '57 chevies with '57 Buick grills? I am jonesin'...
    And- does the installation of said buick grill interfere with the hood latch on the chevy? If so- remedies?
  2. brewsir
    brewsir
    Yea..I need a few pics of how it's done...looks like the pan needs trimmed behind the bumper???
  3. NoSurf
    NoSurf
  4. NoSurf
    NoSurf
  5. fatty mcguire
    fatty mcguire
    I got a pretty nice buick grill i was going to sell, if interested let me kno
    250 shipped
  6. skumbag
    skumbag
    here's a pic of mine, i'm still working on it.
    matt
  7. Rusty
    Rusty
    Pm my dad he should have some to send you of his that was on the cover of Popular Hot Roddin in 84
  8. Boones
    Boones
    from Kent, Wa
    I am going to run one in my 57, hope to be able to install one by next spring
  9. skumbag, could you give us the run down on the install? easy/hard? t*******, ect....
  10. pasadenahotrod
    pasadenahotrod
    from Texas
    WHile you're at it, get a 57 Pontiac hood and bolt it on. You will have to fill a few holes and flatten the raised emblem globe/vee in the front.
  11. skumbag
    skumbag
    well....i get kinda lazy at times so i've been working on it for about the past 3 years.......:eek: it's not as easy as just bolting it in thats for sure!:D i had to do alot of t******* (taking it in and out of the car about a million times...) and it does interfere with the hood latch i just cut it (hood latch) and re-bent it to clear the grille. i'm at work so i'll try to post more pics of what i've done later tonite.
    matt
  12. Gigantor
    Gigantor
    I had a 57 210 post with this grille in it when I purchased it ... and opening the hood was an embarasing pain in the ***. I had to shimmy a long screwdriver between the grille teeth to engage the latch. There's got to be a better way, but I sold the car before I ever got around to fixing it.
  13. NoSurf
    NoSurf
    My '64 impala has a pull tab/rod under the bumper. I will have to get it out in the light and see if it would work on a '57.
  14. 52ChevyBizCoupe
    52ChevyBizCoupe
    from Maryland
    I was gonna trim one of these down to put it in my 52,if anyone has any suggestions about how I should go about doing it let me know :)
  15. flyingpolock
    flyingpolock
    from PHX
    Our old '57....
    Install requires t******* the outermost teeth around the bumper ends (the dagmars, as it were).... I've seen some installed behind the bumperr, but IMO, it doesn't look as clean.
    An inside hood release is the key to your hood-opening foibles, and most can be tucked neatly under the dash to avoid clutter.... GM A-bodies from 68-72 work well, *** would any *gasp* late-model import unit....
  16. KCsledz
    KCsledz
    I am not a big fan of the skinny gills. I found a nice 54 grill that is going in my 57 wagon. And ya like what FLP ya will have to trim the gills to give it a better look.
  17. If you're just looking for ways to see what it looks like in a car, this swap was so popular back in the day that the original AMT 1/25th '57 Chevy 3-in-1 customizing kit comes with a '57 Buick grille option. I'm not sure how easy it is to find that kit now, though, I know they came out with an all-new '57 kit maybe 10 years ago and I'm not sure they made both at once.
  18. swade41
    swade41
    from Buffalo,NY
    I had one of these for sale too, before the cl***ifieds got revamped.
  19. Flamingo_57
    Flamingo_57
    from Rolla mo.
    Heres mine, just finished it. The gravel pan has to be trimmed to clear the bottom of the grill,the dagmars have to be trimmed, the top grill tie bar has to be "pancaked" so that the hood will close, and the ends of the grill have to be trimmed to fit the shape of the bumper. Then, all you have to do is fabricate new mounting points make some new tun signals to mount behind it. (DONT CUT THE TABS OFF OF THE ENDS OF THE GRILL, YOU NEED THESE!)
    Anybody that tells you these grills "fit" or "bolt in" is eithe lyning or has never done it before.
