Cooling a 49 Chevy with a 350/350?
Discussion in 'The Hokey Ass Message Board' started by louder50, Oct 5, 2007.
  1. louder50
    louder50
    from Michigan
    I read the big, long tech archive about doing the 350/350 swap in a 49-54 Chevy, and it answered most of my questions. It said the original radiator worked just fine but I'm wondering, what about the trans? do I need to run a trans cooler? or can they re-core the original radiator and add one to it somehow??
  2. 49ratfink
    49ratfink
    get an auxillary trans cooler and mount it up front. way more efficient, since you are cooling with cool air rather than a hot radiator
  3. Yup, I have a TH400 behind a 350 in my 54 and never had issues with a small aftermarket cooler.
  4. pittsburgholdschooler
    Same here...'51 bus. coupe , 327/350th, stock rad, aftermarket aluminum cooler in front of the rad...never a problem.
  5. 40chev
    40chev
    Definately a trans cooler especially with a shift kit or a stall convert....I never did grasp the concept of putting hot trans fluid next to hot rad fluid...Using a cooler will help knock the heat down on both trans and engine....win win situation...
  6. stickylifter
    stickylifter
    from Detroit
    Same with me too. 50 chevy, 350/350 stock radiator with an add on trans cooler that I mounted in front of the radiator a few inches.
  7. Grizz
    Grizz
    from Austin
    I have a 350/350 combo in the 49, stays cool until I sit in traffic. But I have a non clutch fan and no shroud. Has anybody found a good shroud that will work? Does the stock one fit alright with this combo?
  8. 40chev
    40chev
    Not sure about what shroud will fit but a fan that I found works really well with no shroud is a plastic flex-a-lite....If memory serves me correct it was a 6 blade....In the early 90's I ran one of these on a 69 Ply Valiant with a dual qaud 440 and a 78 dodge aspen radiator.....the car never got above 175 ideling, traffic, didnt matter......The fans are light and pull gobs of air, one drawback is if they are used with a shroud that they make alot of noise, without a shroud they are fine...
  9. Grizz
    Grizz
    from Austin
    Yeah, the fan I have on there pulls plenty of air, but a shroud always makes a huge difference.
  10. deucemanab
    deucemanab
    I Have A 350 Trans With Cooler Mounted Under The Car,
    But In Some Air. Have An A/c So That Takes Up Most Of The Room In Front Of The Radiator.use An Electric ****er Fan.
  11. rusty1
    rusty1
    ....I always mount a trans cooler under the car on the frame rail next to the trans instead of in front of the radiator. Lot less lines involved and have never had a problem with any of em. ...just my 2 cents.
  12. Von Rigg Fink
    Von Rigg Fink
    from Garage
    327/350 combo ..original radiator, aluminum trans cooler out in front of the radiator..works like a charm!
  13. Salty
    Salty
    from Florida
    yup....same here....no issies and its the same application that was questioned....
