Fenderwell headers on a 53 Chevy
Discussion in 'The Hokey Ass Message Board' started by 55project, Sep 21, 2007.
  1. 55project
    55project
    from Phila. Pa.
    Are there any fenderwell headers that fit a 53 Chevy that i can buy and bolt in..??
    Or do i need to get a set from a 55-57 and chop and cut,, or do these fit??
    Or start from scratch??
    Thanks..
  2. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    I hope somebody jumps in hear with an answer to that. I bought a 52 deluxe last week at the Arlington Tx swap meet and plan on making a g***er out of it.
  3. cwatson1953 runs a g***er style '53 mordor w/fenderwells on it.
  4. Kurt
    Kurt
    I have 66-67 nova fenderwells in mine. Had to do a 1/8" pie cut in one tube and pull it in away from the firewall. Otherwise a good fit.
  5. Fishtail8
    Fishtail8
    I scratch built mine, but you're probably looking to go more out the side right...?
      50.7 KB
      63.2 KB
  6. 55project
    55project
    from Phila. Pa.
    I just got a new set of ****** Super Comp, drag tubes. Slip on end, no collectors,, this way i can add to the length then put on a collector and cut a 3" hole in the back side to run a nice hidden exhaust system.
    I figure i only paid $$250.00 for them at a swap meet last week, so i can afford to modify them if needed.. Which i sure they will need.. But they look to be fairly close..
    The only sad part it, i won't know till over the winter when i get started on my toy,, i have others to build for some buddys,and family. Then mine..:cool:
  7. 55project
    55project
    from Phila. Pa.
    Nice job, i bet that took some time and paitiance,, but your right, i'm going to run mine up and over then down, facing the ground..
  8. ...Fishtail8 that's nuts!!! did you do the same on the otherside?
    -marty
  9. Fishtail8
    Fishtail8
    Thanks 55project, there's a few hours there.. lol... Just take your time when doing yours, and be prepared for alot of welding!!
    murder_city_devil... The other side matches.. I'll take a pic when I'm out today...
  10. fiftyfiveford
    fiftyfiveford
    PM Vintage Driveline, they have a bad *** 53 wagon with some cool fenderwell headers
  11. Fishtail8 got any more pictures of your steering set up?
    sorry to highjack....
    -marty
  12. Von Dago
    Von Dago
    from New Jersey
    I bought a set a long time ago from
    Tubular Automotive in Rockland, M***.
    I have no idea if he's still in business. It wasn't a real big operation, but he did nice work and the headers fit.
    I had them on a 53 Sedan Delivery.
  13. S.T.P.
    S.T.P.
    You got it
    Its way less time consuming. I took a total of 4 inches out of mine and I like it. Made new short collectors too.
  14. fastchevy49
    fastchevy49
    Speedwaymotors.com has them for 1935-1948 chevy cars with a small block, I have a '49 that is the same as your '53 and they fit perfect!!
    Part# is 930-0150H
  15. fastchevy49
    fastchevy49
    Here is a shot of mine...
  16. 55project
    55project
    from Phila. Pa.
    murder city devil.> Don't sweat the hi-jack, no problem..
    S.T.P.> I'm glad to hear the 55-57 headers will work, i just got a real nice set with the slip on ends.. I just need to chop and add the collector,.
    And Fastchevy49>> Your car looks great, do you have any other pics of the front suspention.. I'm going to do a single leaf, model A set-up,, just to be alittle different.. But i would love to see how you did yours,, I had a 64 Chevy II i sold on here a few years ago that had the truck set-up. Man, i miss that car.. But my 53 should be pretty cool when i'm done..
  17. Fishtail8
    Fishtail8
    Marty, steering is a stock column, shortened and re-angled. The rest of it is DD steering shaft with DD u-joints from Flaming River. They fit nice around the headers, and weigh half of what the uni-steer ones do... and for $10 more at my parts store... If you want to see some more pics, I'll start another thread for ya...
    55project- How many pieces did your headers come in? I ended up having a 3 piece header on the p*** side with a 4 piece on the drivers, and I still have to pull the inner fenders to get them off..!!
      58.1 KB
      94.5 KB
  18. 55project
    55project
    from Phila. Pa.
    One piece,, i'll get pics soon..
  19. fastchevy49
    fastchevy49
    I bought a complete kit from speedwaymotors and me and a buddy put it in.
  20. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    What steering gear are you using?
  21. fastchevy49
    fastchevy49
    I used a vega steering box and went with a cross steering arm.
  22. fastchevy49
    fastchevy49
  23. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Thats a nice looking setup. I have a corvair box I may try to use in the same manner. Planning on using the vair buckets too.
  24. 55project
    55project
    from Phila. Pa.
    Yep, i second that, look great. How do the springs sit, i know the frames are of a little from front to back in these Chevys? Do they angle in a little?
    And i have a Corvair reverse, steering box, it sits on top and i'm going to try to use some of the factory steering into the process. We'll see:) My only worry is the box looks really small for a heavy car..
  25. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    I went out and measured the 52 frame and the 38 front end and the 52 frame angles in more than the 38 frames does. The mounting points for the 38 springs are wider on both ends than the 52 frame.
