My 29 Roadster project - I want THIS !!!
Discussion in 'The Hokey Ass Message Board' started by mercjoe, Oct 5, 2007.
  1. mercjoe
    mercjoe
    Hey Guys,
    New thread, same thing.
    I'll be using a Lincoln 368 Lincoln, 4sp toploader, original A frame..., and thats much pretty it. Anything else I have no idea.
    I want a late 50s Rod.., not a post war.
    What I want to do with my roadster is achieving a stance close yo this red roadster bellow on the pics.
    Could anyone tell by staring at this pics how that stance was achieved ? someone might know the owner and the car..., what about frame,suspension, links, steering, etc
    I want to use wider wheels and tires as well .., what sizes would be period correct for late 50s early 60s ?
    Thanks for your help
    Diego
  2. Nick32vic
    Nick32vic
    wingnutz owns that car
  3. mercjoe
    mercjoe
    WingNuts.., willing to help ?
    Thanks
    D.
  4. mercjoe
    mercjoe
    anybody home ?
  5. Jaker
    Jaker
    I don't think that's wingnutz car, and I"m a hindu.
    and drunk
    -Jake
  6. Jaker
    Jaker
    o wait yeath it is
  7. mercjoe
    mercjoe
    So where is wingnutz......, Wingnutz !!!!
  8. xadamx
    xadamx
    Please, be patient...I am getting anxiety reading these two posts about your '29! Take a deep breath, you will get this figured out. If you send Wingnutz a private message, I am sure he will get back to you when he signs on. As for the stance, my old roadster had a similar profile...except not so low in the back. Looks like he used a Model A frame with a 4" dropped front axle with hairpins, channeled the car the width of the frame, and z'd(or stepped) it in the back with the spring behind(maybe, speculation.) Steering looks like cross-steer as there is no visible pitman arm or drag link.
  9. mercjoe
    mercjoe
    Im sorry Adam, you are right ...... Ive already wrote WingNutz but he never wrote back..., maybe he got tired of my posts too..:(
    D.
  10. xadamx
    xadamx
    I am sure he will get back to you. I can't wait to see this car come together for you, good luck. I will email some pictures to you soon...
  11. TimDavis
    TimDavis
    I though hot rods sat down in the front, up in the rear?
  12. xadamx
    xadamx
    Different strokes for different folks, I guess. Not a big fan of the taildragger hot rod myself, but have seen quite a few from the late 50's and early 60's that were level or a little dipped in the back...
  13. mercjoe
    mercjoe
    Somehow out off topic but Ive been wondering for some time who owns this coupe ? anybody knows ?
    Thanks
    D.
  14. 1930 ratrod
    1930 ratrod
    from colorado
    merc joe i think that was sold on ebay a couple of months ago.
  15. mercjoe
    mercjoe
    Ok, I think my best choice will be to gather all the pics from similar stance cars and ask how they were done.
  16. hodaddyo
    hodaddyo
    hey mercjoe, jim sibley probably knows he built the car, he's on the hamb.
  17. Here's a good article on early custom wheels. He is also on the H.A.M.B. According to the article, the wheels like the one in the photo came out in '63. I'm not too sure what year the wider ones were available, maybe send him a P.M.?
    P.S. Another vote AGAINST the tail-dragger stance.
  18. mercjoe
    mercjoe
    Hi Richard, you forgot the link.
    I want an even stance, slighlty lower in the front but not too much.
    just like the blue coupe
  19. http://www.roadsters.com/wheels/
    I'm an idiot. Funny quote-"Fenton wheels have as much prestige as a Spark-O-Matic shifter, and about as much cl*** as your daughter's boyfriend."
    P.S. The blue coupe has it nailed.
  20. mercjoe
    mercjoe
    Hey hodaddyo, do you know his nick ? what car ? the blue coupe or the red roadster ?
    Thanks
    Diego
  21. mercjoe
    mercjoe
    Richard, Im totally an ignorant. What do you mean with "it has it nailed".. ?
    Im following the link now.
    Thanks !!
    Diego
  22. That means I like it!
  23. mercjoe
    mercjoe
    Great info...
    Any way, I think Im gonna get a set of standard reversed wheels.., beauty rings, repro Ford cups and that will do it.
    I'll just use wider wheels..., lets say 15x7 for the rear at least.
    I guess thats acceptable for a late 50s rod, isnt it ?
    Thanks Richard
    Diego
  24. hodaddyo
    hodaddyo
    jim built the blue coupe. i think his screen name is jimsibley as one word, check the members section an pm him. he is a good guy. i'm sure he'll give you some info on the build. good luck
  25. Sorry for the delay...been to busy driving the roadster...!
    As for the stance it was achieved by a flat frame with a kick-up in the rear and then channeling the body the width of the frame.
    Basically Bobbleed built a flat frame based on the stock set of rails... channelled the body.... mocked it up so that it had the right stance with the tires and wheel combo... and designed the rear kick-up to fit the Quickchange and triagulated 4-bar within the trunk confines!
    It's a lot simpler than the double Z'd or Bleed Sweep frame and with a simple 4" dropped front axle I was able to stabilize the front end and get the stance I wanted using the adjustments on the Coil over mounts in the rear.
    Bob offers an adjustable spring perch for traverse mounted springs that'l give you stance tuneability as well.
    Contact Bobbleed for his ch***is help and parts!
    The frame is longer than a Stock Model A as well as the wheelbase... the main thing is to mock it up with the engine, wheels and tires until you get the proportions and the stance the way you like it.
    p.s. I'm really "diggen" on that coupes pipes...!
    Good luck.
  26. mercjoe
    mercjoe
    Do you remember how many inches were finally added to the lenght of the frame ? how much drop on the kick up ? did you use the spring over the axle ?
    Thanks !!!
    Diego
  27. I have no idea how much longer my frame is compared to "stock" but my radiator is mounted in front of the spring perch so that the radiator shell is at the right height with the front of the cowel (very important).
    Don't forget to leave enough room for your waterpump, Fan, and some room to play around with the distributor.
    Always build with the mindset that if something breaks (as they all do!) you can take it appart and repair it quickly without having to remove the whole body or other major components...!
    A little thought before building will save a lot of heartache later.
  28. bobbleed
    bobbleed
    from Awesome
    It is a 106 inch wheel base if i remember right.......
  29. mercjoe
    mercjoe
    Just 106" ??! it looks like it was extended 5" to 6" . Doesnt it ?
  30. It's 106" and accomondates the 455 Olds engine beautifully.
    Mock your car up with jackstands wheels, tires and motor for the desired stance.
    This should give you a pretty good Idea how you should lay out the rails.
