Can't find info ('63 Mercury Monterey)
Discussion in 'The Hokey Ass Message Board' started by starlitelounge, Aug 6, 2007.
  1. starlitelounge
    starlitelounge
    The Merc Monterey 4 door had the big 390 in it in 1963??
    What is the stock carb setup for these cars?
    TIA
  2. DrDano
    DrDano
    Alliance Vendor
    I believe that car would have had a 390 stock, yes. The likely carb for it was a Autolite 4 barrel. My same setup on my Galaxie had a ton of power, but it didn't like staying tuned. It also loved fuel. I've since swapped to an aftermarket 4 barrel intake and Quadrajet. I still have both if you are interested in a setup for your car.
  3. starlitelounge
    starlitelounge
    Thanks for the info. I'm looking at getting a Merc Monterey for a grocery getter and putt-putt around here...just wanted to know how much KY to bring with to the gas station after I buy it.
    And I'm interested in that carb set up if I get this ride.
    Thanks for your help.
  4. Shifty Shifterton
    Shifty Shifterton
    Every 390 I've known got about 9mpg, but made power like it was getting 40mpg.
  5. If you install an aftermarket aluminum intake you'll get better fuel economy, mainly just by shaving 70 lbs off the front of the car!
  6. Jimv
    Jimv
    could also be a 352 or a 360 maybe, but i think the 352 was common, My 63 ford had one witha autolite 2BBL.
    JimV
  7. Jimv
    Jimv
    I stand corrected, no 352 or 360 in the merc.
    JimV
  8. Fat Hack
    Fat Hack
    from Detroit
    I also have a spare Autolite 4v carb from a 64 Ford 390 if you want it. Probably good for a spare or "parts" carb at least?
    (I'll be replacing it with a Holley when it comes time to drive this thing!)
  9. squirrel
    that sums it up nicely!
    yeah, don't worry about what carb it has, it'll get ****py mileage either way.
  10. IIRC its a Autolite 4100.
  11. DrDano
    DrDano
    Alliance Vendor
    I gotta disagree here Squirrel. :eek:
    My '62 Galaxie has seen 20mpg pretty consistently the past few years on the highway. It has a 800cfm Quadrajet with pretty big primary jets and secondary rods, Performer RPM intake, stock 3.00 gearing and weighs almost 5000lbs when loaded with all my camping and road trip ****. With the stock Autolite 4 pot carb I would never get above 10mpg.
  12. Cars built in Oakville ( pre auto pact days) could have 352's in them but 360's were a truck motor from later.
  13. 34underglas
    34underglas
    My first car was '63 Monterey.
    I loved the electric rear window you could lower and raise:)
    worked great during Dove season, stick a couple guys in the back, lower the window, and blast away:eek:
    Vance
  14. squirrel
    in 62 they put the 352 in mercs, but not in 63
  15. 64T-bolt
    64T-bolt
    from Kansas
    you're right. . .good catch. .
  16. DISKOROB
    DISKOROB
    from San Diego
    I just bought a 63..What does the aftermarket 4 barrel intake and Quadrajet do?
