Removing painted on pinstripe
Discussion in 'The Hokey Ass Message Board' started by PRoz, Oct 15, 2007.
  1. PRoz
    PRoz
    I know there are a few pinstripers who hang out on the HAMB.
    I've got a car, newly purchased late model Impala, I want to remove a painted on dual pinstripe from.
    I've tried acetone, reducer,lacquer thinner, etc and without LOTS of elbow grease it doesn't move. There's probably 30 feet of stripe on the car and it will take hours just rubbing with the above.
    Any ideas and help is appreciated.
  2. novatattoo
    novatattoo
    from Canton,OH
    Easy off oven cleaner worked for me.
    Later,Bill.
  3. HOTRODPRIMER
    HOTRODPRIMER
    Have ya tried compound? HRP
  4. Slag Kustom
    Slag Kustom
    after you use easy off oven cleaner you will need to sand the marks off from where the stripes raised the stock paint.
  5. Unkl Ian
    Unkl Ian
    Depends on what type of paint was used,and if it was catalized.
    Easy-Off is an old trick for removing 1-Shot,
    works better if you can keep the area wet.Of course,
    the new easy-off isn't as strong as the old stuff.
    If it's catalized Urethane,then you might need a buffer with compound.
    If you can find out who did the stripes,you might be able to figure out what they used.
  6. PRoz
    PRoz
    Thanks guys.
    I don't think it's catalyzed. I did a small spot with reducer and some scotctbrite and it took it off but scuffed the clear coat.
    I'll try the easy off and get some compound for the buffer, I'll need it no matter what.
  7. Unkl Ian
    Unkl Ian
    You can soak some paper towels in Easy-Off,
    apply over the stripes,then cover in plastic.
    Holds the chemicals in,so it works faster.
    Otherwise they evaporate too quickly.
  8. Lil' Toot
    Lil' Toot
    from Tulsa, OK
    Remember to get the easy off in the yellow can, not the low fume stuff in the blue can.
