Tech: How to safety wire
Discussion in 'The Hokey Ass Message Board' started by officerfalfa, Oct 16, 2007.
  1. CB_Chief
    CB_Chief
    from Oklahoma
    My buddy safety wires the header bolts on his drag car (7.4 ET) to keep the bolts from backing out. I was having similar problems on my son's pickup so we drilled the header bolts and wired them one weekend. No leaks and haven't had to tighten them in 4 years.
  2. joeycarpunk
    joeycarpunk
    from MN,USA
    Cool post, Ford banjo rears internally use safety wire.
  3. no55mad
    no55mad
    It would take someone in the field of education to find these discrepancies.
  4. Sawracer
    Sawracer
    from socal
    I have made the same mistake on my car and was busted by a hamber. Thanks for the post. Right or wrong, a loose nut is better than no nut, or is that bolt?
  5. ig'nant
    ig'nant
    Not only that, but there's so much bad-***itude to that particular car, you could look at it for hours and not see the safety wire. That said, it's cool to see when details like that are done right. Hopefully that car's builder/owner (Eric, I think it is) will see this thread and correct what could be the only flaw on that car.
  6. Columbus Snake
    Columbus Snake
    Don't need no stinken Safty Wire Pliers.
    Easy enough to twist by hand once you get the knack.
    Usually looks better too - More control.
    Truck64 likes this.
  7. officerfalfa
    officerfalfa
    Do you mean drilling through the bolt and nut like you would for using a cotter pin? If that's what you mean, in aviation you would just use a cotter pin. I have seen it done on a race car that way. Looked a little sloppy to me. Not correct for an aviation application if that is what you're after.
  8. Bort62
    Bort62
    I ****ing hate safety wire!
  9. Digger_Dave
    Digger_Dave
    This explanation is taken from the site provided earlier.
    7-42. DRILLED HEAD BOLTS (AN73
    THROUGH AN81). The AN drilled head
    bolt is similar to the standard hex bolt, but has
    a deeper head which is drilled to receive safety
    wire, ... abbreviated ... lengths are universally, functionally,
    and dimensionally interchangeable.
    The above information refers to AIRCRAFT.
    For automotive use; the size of the safety wire hole is small enough NOT to compromise the strength of the fastener.
  10. Great tech (thanks to 64 Dodge for where to get pliers and such).
    Safety wiring was also used on many race cars, especially European cars. But I have also seen it on Shelby cars and Cunninghams.
  11. Hahahaha!! I had to put up with it for two years... I can't imagine doing it for 13, you're the man! :D
    I like your post... gets my vote for tech week!
    Sam.
  12. Actually it would take an ex-aircraft mechanic with an A&P license to find those discrepancies. That and someone who pays attention to details and knows a lot about hot rods.
    Sam.
  13. Frosty2
    Frosty2
    from Hambone,IN
    Thank you for the great posts.I have learned something today.
  14. 57JoeFoMoPar
    57JoeFoMoPar
    Excellent tech post. Also worth mentioning that many sanctioning bodies require safety wire on critical suspension and ch***is components
  15. XSCOOTERX
    XSCOOTERX
    from Brier,Wa.
    My buddy would see it...he's an ****qwerky SOB...:rolleyes:
  16. g-lover51
    g-lover51
    from Dallas Ga
    Safety wiring is almost an art, I am a helicopter mechanic in the Marines and i love to do it. I have gotten to where I use my fingers more then I will safety wire pliers, and I can get it just as tight if not tighter. Plus it looks damn good when done right. Great tech article
  17. 26TCoupe
    26TCoupe
    Did I mention how much I dislike safety wire, especially in 120 degree heat over in the sandbox! You're right though, it is nice to look at after it is done.
  18. NJVadala
    NJVadala
    Oh man, what a good tech article. I'm going to try this on my car some time soon. Thanks!
  19. Please make sure this goes into the tech section.
  20. BigMikeC
    BigMikeC
    I thought everybody knew how do do this.:eek: :D
  21. officerfalfa
    officerfalfa
    I meant to say that Aircraft Spruce is also a good source!
    I've been an A&P for 8 years and an IA for almost 2 years.
    Thanks for all the positive feedback guys!!!
  22. oldmule
    oldmule
    from Colorado
    I like that word. Defines me pretty well too. I notice little stuff like this too. Now that I know how it's supposed to be done/look, I'm going to suffer. I could be looking at the coolest rod in the world and still notice a tiny blemish. It ****s. :( But, it helps in problem solving.
    PS, the link on the drilling jig tech doesn't work. I would like to see that one too.
  23. Digger_Dave
    Digger_Dave
    Sorry about that oldmule.
    There wasn't a "link"; I just "popped" my little TECH in because I had just made a new size.
    Here is what was in it; sorry NO pictures.
    JIG for drilling SAFETY WIRE HOLES
    Next thing we need ... the "jig" for drilling the safety wire HOLES in nuts and bolts that don't have the holes.
    The bolts are drilled across the centerline; and the nuts drilled to one side.
    Here is my "TECH" on "How to make your own safety wire hole jig."
    It's pretty simple, it holds the bolts or nuts in the "jig" - which is held in the bench vise - with a pilot hole to guide the drill bit.
    There are different sizes for the different sizes of hardware.
    Start with a piece of flat stock about 1/2" to 3/8" thick, with holes drilled
    for the size - diameter - of the head/nut with a slit cut on one side.
    (at the centerline of hole)
    The pilot holes - drilled on the EDGE of the flat stock
    beforehand on a drill press - are positioned over the head/nut.
    The size of the pilot holes are the same as the diameter of the safety wire.
    There are two different jigs for each size, one for nuts with the pilot hole
    offset to the side.
    And one for bolts with the pilot hole centered.
    On larger hardware you can actually combine the two together.
    (pilot holes side by side - one centered, the other to the side)
    Then a "C" clamp is used to "squeeze" the slit closed
    to hold the bolt/nut while drilling the safety wire holes.
  24. oldmule
    oldmule
    from Colorado
    Thanks Dave, got it figured out. Pretty simple too.
  25. stealthcruiser
    stealthcruiser
    Tee hee hee.:D
  26. coupemerc
    coupemerc
    I know that nuts are to be drilled to one side but how should they be safety wired? Can someone post a picture of safety wired nuts? Thanx.
  27. Roothawg
    Roothawg
    The same as pictured above.
  28. Mr48chev
    Great tech article. I learned to do it in 1966 when I was going through one of the two week schools for Boeing mechanics.
    For the guys in the PNW you can usually find the pliers in pawn shops and tool stores that cater to Boeing mechanics around Seattle and Tacoma areas.
  29. scootermcrad
    scootermcrad
    Here's a good thread that needs to be bumped up again. Safety wiring is an art form for sure!
