How to ID a '32 heavy axle???
Discussion in 'The Hokey Ass Message Board' started by skoundral32, Oct 19, 2007.
  1. skoundral32
    skoundral32
    Any help on how to ID a '32 heavy axle? Thanks!
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    One quickie way is that the perch bolt bosses are slightly recessed in the web of the I-beam due to the increased thickness of the web.
  3. revkev6
    revkev6
    from ma
    second axle from the top is a 32 heavy, once you see one you don't need anything to "id" it
  4. Noland
    Noland
    If you dont mind me asking
    whats so great about that axle?
    Is it that much heavier
  5. SUHRsc
    SUHRsc
    it looks better :D
  6. banjorear
    banjorear
    I think someone did some compare and contrast on all the axles. Even though they look stout, they aren't that much heavier. I'm thinking +/- 2 lbs.
  7. revkev6
    revkev6
    from ma
    it's not that they are weigh more that they are called "heavy" axles. it's that they have a bigger I-beam between the spring perch and the kingpin boss. makes the axle look weird not dropped but PERFECT when you drop it.
  8. skoundral32
    skoundral32
    I think I got it. Great info. Thanks everybody.
