Help- edmunds 2x2 intake id
Discussion in 'The Hokey Ass Message Board' started by hammeredt, Oct 22, 2007.
  1. hammeredt
    hammeredt
    Can anyone positively id this intake. I believe it to be for an olds. I am unfamiliar with this style intake for the early olds- the offy,weiand,edebrocks mount from the "inside" of the intake, not the outside as seen here. Please someone help make my day. Just got my stick shift this week end so this would just be the icing. Thanks J-
    More pics avail if needed.
  2. PackardV8
    PackardV8
    Well, Edmunds made many intakes for Cadillac/Studebaker, but this is NOT one. They did not have water in the intake. Looks like an Olds to me.
    thnx,
  3. Chris
    Chris
    Looks Mopar to me...
  4. Dakota
    Dakota
    from Beulah, ND
    that is almost definately Buick Nailhead
  5. Chris
    Chris
    Now that you say that...Yes it is nailhead
  6. Rudebaker
    Rudebaker
    from Illinois
    The Edmunds 2 X 2 I just bought has "STUDE" barely visible on the underside, you might check the bottom over with a strong light but the other's probably "nailed" it.
  7. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Cadillac, nailhead Buick, and Studebaker all used dry intake manifolds, i.e. the water crossover and thermostat were incorporated into the water pump or front cover.
  8. backyardbeliever
    backyardbeliever
    IT IS olds 49-55 303-324 may fit 56 #10 heads but the ports would need opened up a bit
  9. hammeredt
    hammeredt
    Thanks for the input guys. I had over looked the nailhead. In the pic below it looks like there is too much angle to the gasket seats to be nailhead though- and certainly the water crossover eliminate it as a possability as well. Haven't received it yet, but will check the bottom for a mark. Thanks again. J-
  10. couverkid
    couverkid
    looks like olds to me.
  11. 7&7
    7&7
    from Colorado
    I have a Edmunds for a Olds and it says on the bottom 49-53 olds. If you need pics just PM me. Mine is not polished and you can read everything perfectly. Swap Meet $50.
  12. hammeredt
    hammeredt
    Well I wish I paid 50 bucks, but still the price was worth making me smile like my face was green and round. Now combined with the three speed stick setup I got this weekend...well I'm a happy guy. Thanks all. J-
  13. 7&7
    7&7
    from Colorado
    Here are the pics
  14. hammeredt
    hammeredt
    7&7,
    Thanks for the pics. Now that looks like an olds intake and sadly not like mine- though they do share a lot in common. Can't quite see in the 1st pic; does it read edmunds or edmunds custom? J-
  15. 7&7
    7&7
    from Colorado
    Just Edmunds
  16. superchargednailhead
    Its Olds they made 2 just like caddy 1 with solid casting and 1 you can see between the ports positive its not nailhead.
  17. couverkid
    couverkid
    Edmunds made 2 styles of olds intakes. The one you are buying I believe to be the later version. I have had both styles.
  18. Crestliner
    Crestliner
    53-54 Lincoln. Thats what my Edmonds papers show. #727
  19. 7&7
    7&7
    from Colorado
    If it is the lincoln then I have a line on the engine. Complete.
  20. There are two on that nasty Auction site, with decent pictures. One for a Stude 258 and one for a Hemi 354. Just search Edmunds. Good luck.
  21. idaholc
    idaholc
    from Boise, ID
