Paint Stripping A Car Down???
Discussion in 'The Hokey Ass Message Board' started by Garage Concepts, Oct 23, 2007.
  1. Garage Concepts
    Garage Concepts
    Looking for the best way to (Paint Strip) a car down to bare metal without warping and the cheap way.
  2. Speedwagen
    Speedwagen
    dip or soda blast
  3. Plastic media blast
  4. NJVadala
    NJVadala
    Soda blast it
  5. 8flat
    8flat
    I prefer soda or gl*** media blasting, but it gets a little pricey. If you're looking for the cheapest, I seriously think it would be chemical stripper. But, it's pain in the ***, takes more time, and makes a mess. I've done it, and it usually works OK.
  6. Garage Concepts
    Garage Concepts
    I've used chemical stripper before and my understanding is you need to wait for really really hot weather in order for it to soak and penetrate thru. Unless I'm using the wrong brand (AIRCRAFT PAINT REMOVR)
  7. Creepy Jack
    Creepy Jack
    from SoCal
    I've had really good luck with Aircraft Stripper. Yes, it makes a mess, but with a little prep (masking paper under the car) it can be controlled.
  8. guthriesmith
    guthriesmith
    Aircraft stripper is the way I always do it. If it is applied liberally, it works really well and as mentioned above, cleanup can be controlled fairly easily. It usually takes me about 3-4 gallons to completely strip a full size car depending on how much paint is on it. Just don't get it on you. It will burn.
  9. My '34 is in the shop now and getting it's paint stripped the "old fashioned" way.....single-edge razor blades and plenty of "elbow grease". I remember seeing cars stripped this way when I was young (early '50's).
    Jim Winter
    The Hot Rod Grille
    www.wvpinball.com
  10. premium
    premium
    from Goergia
    yeah some aircraft stipper, let it soak in and ive got a steel wheel cup put on my angle grinder and it takes it down pretty good then give it a good sanding. works great. faster then what i can sandblast with my lilttle home compressor, but yeah it burns like a ***** when it gets on you....not if.
  11. Creepy Jack
    Creepy Jack
    from SoCal
    Oh yeah, you WILL get it on you. Doesn't hurt for long, though. :D
  12. evans8404
    evans8404
    anybody know about the temp deal with the aircraft stripper? I've got some at home and I want to do my hood but it' says only use between 70-90 F - we aren't looking at lots of 70+ days anytime soon. is it just less effective when it's cold?
  13. Garage Concepts
    Garage Concepts
    What Application is more effective. Spray On or Applied by hand? If applied by hand what way works best, Brush On or Rag On? I just want to be sure before i attack my car with this stuff...Thanks
  14. Jcurtisward
    Jcurtisward
    from Tucson, AZ
    Aircraft paint remover is the way to go, but someone said wait for hot weather... dont. if you put paint remover on the hot metal it doesnt work as well. it still works, just not quite as well.
  15. old dirt tracker
    old dirt tracker
    from phoenix
    make sure you get aircraft stripper in the blue and silver can. brush it on heavy. i get mine at home depot.
  16. 8flat
    8flat
    Another note: if you want to keep the paint intact on the door jambs, run a line of good quality masking tape down your door seams. That helps keep it out of the jambs.
    Get one of those steel razor blade holders, that makes for a great s****er that's sharp, and easy to swap blades. The paint will s****e right off, usually.
    I hadn't thought of a wire wheel on a grinder. Too much speed might make a mess though?
    Also, I used to use a brand called "Zip Strip". It was good stuff, not too temp dependant. Hope this helps.
    Gary
  17. 8flat
    8flat
    PS: get a good paint respirator, that ****'s nasty to breathe.
  18. Bluto
    Bluto
    I use 3M clean and strip discs
    No chems or blasting!
    It takes 3-4 8-9 inch discs to clean a car up
    You can do it yourself and sweep up the mess
    One thing... 3M charges about the same for a 3'' disc as a 12'' so buy the big ones and cut out the size you need
    I doesn't hurt the body unless you lean on it hard and chews body filler very well
    I use it to clean old alunimum race car bodies .... no problems
    Good luck
    Here's what they look like
  19. Garage Concepts
    Garage Concepts
    Are they flat front disc? Cut to size:confused:, I'm working on my Lincoln and I'm going to try to strip it down. Do you recommend applying paint stripper first and finishing it off with clean and strip discs.
  20. CheaterRome
    CheaterRome
    from URANUS
    I have been using aircraft remover / paint stripper at the shop and on personal projects for awhile and Paint it on in one direction only, if you cross hatch you seal it in and it's reactive properties.
    Wait 5-10 minutes and have fun s****ing .
    Wear rubber gloves and a respirator.
    Take gloves off before going pee.
    Enjoy,
    Jerome
  21. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Some points when using stripper- DO NOT USE A WIRE WHEEL ,air
    or electrical powered. Stripper traveling at 150 m.p.h. off the end
    of a wheel will take out your eye before you can save it. I know
    even if I tell ya too, ya won't ware goggles, but there's nothin'
    cool about an eye patch! Even before you start to strip your project,
    set out a fresh five gallon bucket of water. This is your eye wash
    station! Yeah, I know, ya arn't planning on getting any in your eyes
    or on your skin, neither were the thousands of guys who **** them-
    selves up using stripper every year. Avoid getting any stripper on
    rubber or plastic parts, if you do wash it off asap! Pizza boxes work
    great for catching stripper and dead paint as it fall off the sides of the
    job. Place cardboard or heavy paper on the shop floor around the
    vehicle, and upon removal allow it to dry and air out before you put
    it into the trash. Always use rubber gloves when using stripper.
    S****ey Devils C.C.
  22. highboyjohnny
    highboyjohnny
    from new york
    I've always had good luck running over the paint quick with a da with a piece of 40 grit first to cut it up then apply the stripper the scratches help get the stripper deep and it works a little faster
    also put on 2 or3 pairs of rubber gloves that way you can pull off the nasty ones and keep working good luck
  23. Goozgaz
    Goozgaz
    :eek: :eek: :eek: :eek: :eek:
  24. Do a real good job, neutralizing it with water. I'd used to take scotchbrite over the stripped area while running water over it; cleans up the scraggly leftover stuff. If you don't neutralize real well that **** will bleed through your primer.
    After it's rinsed, you can take you favorite wirewheel, strip disks or whatever over it. I use 80 git on an orbital DA. or 40 grit on the thick **** that didn't strip real well.
  25. Kustom7777
    Kustom7777
    from Austin, TX
    those 3M stripping discs bluto posted work fantastic...
  26. Bluto
    Bluto
    I don't own 3M stock....... these work and it's dry and sweepable!
    They gang em together to strip floors
    Sometimes you can find the big ones on ebay 18"-24"
    Cut out the size you need poke-a-hole in the middle and put em on your grinder
    They do like a back-up rubber pad and Don't like sharp edges
    Most of my cars are old 0-2 thin alloy Don't hurt em! I did a Mag body with this ****
    No more F'n chemical mess
    Hey it's 3 am here jetlagg's a *****!
  27. lrs30
    lrs30
    from Kentucky
    When I worked at a chain autobody shop where we'd paint up to 20 cars a day(yhea and they looked like it also). We used a Chemical Stripper call "Strip It Dry" it worked great, you scuff the surface with 80 grit DA pour on the stripper let sit for 30 minutes and then with a plastic s****per s****e it off no gooey mess to deal with just dry flakey paint, then remove the rest with finer grit sand paper. I just did a search and did not find it anywhere, this was about 10 years or more ago..
  28. metalman
    metalman
    Couple more comments on chemical strippers. Works good on old enamals but a messy pain on lacquer. Lacquer doesn't blister up, just turns gooey. Will also come back and haunt you if it gets into a seam or edge, it will wait till your new paint to show you what you missed while cleaning it up! I prefer the stripping disc also, quicker and much less of a mess.
  29. mikhett
    mikhett
    from jackson nj
    Ditto what Bluto said. Screw the Chem strip i dont use it anymore. Ive been using the 3m stripper discs. Much cleaner and cheaper.
  30. 29bowtie
    29bowtie
    These are the greatest innovation in years.I agree with Bluto this is the way.Wear a respirator for the paint dust though.;)
