What's your favorite spark plug?
Discussion in 'The Hokey Ass Message Board' started by Abomination, Oct 23, 2007.
  1. Abomination
    Abomination
    Just curious, but what's everybody's favorite spark plug?
    Here's mine :) :
    ~Jason
  2. Abomination
    Abomination
    Come to mention it, I think warbozz on here has the remnants of an entire WWII spark plug re-manufacturer's warehouse inventory, which is a very cool find.
    Maybe he'll chime in. :)
  3. buzzard
    buzzard
    Alliance Member
    I kinda like #3 cause it usually looks the best when I check 'em.
  4. Bullington
    Bullington
    Varcons
  5. pan-dragger
    pan-dragger
    autolite, thats what i use.
  6. Ol Deuce
    Ol Deuce
    from Mt. U.S.A.
    CHAMPION N59DR on gas a the salt they do really good in a 301 hemi '
  7. Rich Rogers
    Rich Rogers
    Autolite seems to have helped everything I've had for the last 30 years to start and run better. They last longer too
  8. SinisterCustom
    SinisterCustom
  9. Ford Freak
    Ford Freak
    Autolite, if not available then Motorcraft.
  10. hudsoncustom
    hudsoncustom
    Anything but Autolite. I have had SO many problems with Autolite's it's not even funny.
    I once re-wired a motorcycle 3 times, replaced the generator, replaced the coil, replaced the ignition box, all to find out that the BRAND NEW Autolite plugs I had installed weren't sparking.
    nice.
    Autolite can lick my bag as far as I am concerned.
  11. skajaquada
    skajaquada
    from SLC Utard
    another for autolites...had nothing but good luck with them. hell, they are the only plugs that my 50k volt HEI won't burn up.
  12. DYNODANNY
    DYNODANNY
    I use Champion Brand they seem to be the ones that work for me.
    c59cx and c57c
  13. Abomination
    Abomination
    Damn, gentelmen!
    I didn't know what a can of worms I've opened!
    ~Jason
  14. Noland
    Noland
    I like the type that manage to spark
  15. The37Kid
    The37Kid
    The Twin burn out one side flip it over and keep touring.
  16. NITROFC
    NITROFC
    Comic character Barney Google and his horse Spark Plug
  17. RadioFlyer
    RadioFlyer
    I prefer AC Delco's.
    Alex.
    Somebody had to say it.
  18. Boynamedsue
    Boynamedsue
    NGK depending on the application depends on the plug type but i try to stick with NGK. they seem to work pretty slick for me.
  19. Thumper
    Thumper
    Blue Crown #1
    SA Fire Injectors 2nd :D
  20. The37Kid
    The37Kid
    Hopped up racing Spark Plug.
  21. cuznbrucie
    cuznbrucie
    In my flathead I run NGK B6L's.......excellent plugs......#2 I like Autolite and #3 Champions......
    My $0.02
    Brucie
  22. Jimv
    Jimv
    anything BUT champion, usually AC in GM, Autolite in Fords
    JimV
  23. Lil' Billy
    Lil' Billy
    from Georgia
    That's my favorite spark plug.
  24. AHotRod
    AHotRod
    Champions use Champion Spark Plugs.
  25. rusty48
    rusty48
    I'm with Jimv,never had good luck with Champions ACs seem to run better in a Chevy,Autolites in a Ford.
  26. Mudslinger
    Mudslinger
  27. shortyforty
    shortyforty
    from NH
    I pretty much use Autolites.
    I did an experiment back in the 60's when I worked at the service station after high school. In those days a lot of people would just have their plugs cleaned, tested and put back in. We had a plug tester that was connected to the compressed air. You put the plug in and slowly turned up the pressure while pressing the spark generator. You could see the spark through the little gl*** window.
    Seems that of the older plugs the Autolites lasted longer, next the AC and last was the Champions verus how much air pressure (compresion) was applied.
    One day I took a brand new plug of each one and tested them.
    Well the Champion ran all the way up to 140 psi with no trouble. The Autolite and AC only made it to about 100 psi.
    So my conclusion was that Champions were better for short term high compression performance and the others were for lower compression and longer life.
  28. skajaquada
    skajaquada
    from SLC Utard
    only 140? my engine makes 175-180psi, how's that factor in? now ya got me wondering :p
  29. Autolite, then AC Delco..
    Those Bosch Platinums have got to be the biggest pieces of **** I've ever had to throw away. I've never bought them, just changed them out of many many customer's cars over the years.
    Maybe they work good for VW's. Thats the only thing I've seen a Bosch plug not **** up.
  30. 29bowtie
    29bowtie
    NGK=No Good Kind,try testing and gaping plugs for a 16 Plug Hemi,which you change for every p*** down the track.Usually one in four are duds,and these are the $8 each ones.
