Flatheads 101: 21 Vs. 24-Stud
Discussion in 'The Hokey Ass Message Board' started by Ryan, Oct 25, 2007.
  1. Ryan
    Ryan
    ADMINISTRATOR
  2. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
    THANKS RYAN!! as a new comer to the flathead scene i still have many questions! and that was one of them-thats why i love the HAMB
  3. Magneto349
    Magneto349
    Sweet! Another thing to put in my flathead notebook! Thank You!
  4. Retroharley
    Retroharley
    I never knew that. Thanks for sharing. Now I'm going to always clance at the center studs when I see a flathead engine.
  5. skajaquada
    skajaquada
    from SLC Utard
    i always thought it was the waterneck location that gave them away...?
  6. srosa707
    srosa707
    from Sacramento
    Thanks for clarifying.
  7. Bruce Lancaster
    Bruce Lancaster
    They came both ways on 21's...
    Probable reason for change: 21 had a stud directly below centers of bores, and boring to 3 3/16 left only a scary amount of iron between stud and bore.
    I think they changed the tooling in preparation for the intro of the bigger bore engines to keep tooling as common as possible between 221 and 239.
  8. ROBERT JAM
    ROBERT JAM
    Hey Ryan that is just great info.Just two days ago I was looking at a flat head and counting the studs.It will be easy now Thanks!
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    32-36 21s had water pumps in the heads.
    37-38 21s had water pumps in front of block like 38-53 24s.
    That stud line is a great tip to identify the stud count. Thansk for the tip.
  10. continentaljohn
    continentaljohn
    21 stud/bolt hard to find speed parts and very expensive (Arm &Leg ) Were the 24 stud/bolt speed goodies are abundant and in a reasonable price range. The 24's also offer a much wider range of speed accessories.
  11. SlamCouver
    SlamCouver
    from Brazil, IL
    Awesome bit of info, if you remember other tricks let us know! i require tricks and tips.
    thanks
  12. Lil' Lance
    Lil' Lance
    thats a good way to look to tell the difference. i always before just looked at the bottom of the head. 2 bolts below the bore=24stud, 1 bolt below bore=21 stud. but cool hey either way works!
  13. 36Brua
    36Brua
    Does it hold true a 21 stud head has 5 studs across bottom of head vs 8 on a 24 stud? xYz
  14. Rand Man
    Rand Man
    . . . waterneck location that gave them away...?
    No the 59A series (center) and the later 8BA series (front water neck) both have 24 studs (or bolt holes).
  15. VAPHEAD
    VAPHEAD
    That's how I tell at a glance.
    and the 5 are wide spaced,can spot it across the parking lot.
  16. Very interesting.
    Just wanted to throw in another interesting flattie into the mix. This is an aircooled prototype that is in Speedy Bill's museum (that place is worthy of its own feature sometime).
    Thanks for the info Ryan.
  17. synthsis
    synthsis
    just more info for me to absorb. thanks for the write-up!
  18. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I like that little trivia stuff!
  19. Old Roadster
    Old Roadster
    Good Stuff.......
  20. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    If there was a market that could support this type of 21 stud venture, I'd continue with it. Tooling alone is close to $11.5 K up front.
    Then you still gotta get the casting done,and machine em up. Are HAMBers game to buy if I were to take this chance.
    They'd be in the same price range as the Flatty Caddy's.
    If you need em. Let see what we can make?
  21. Noland
    Noland
    Thanks
    I always wondered
  22. continentaljohn
    continentaljohn
    Kevin, I don't even see many in the cars anymore. Most seem to have been replace with modern iron. I would like to put one together in the future. Keep us in mind for some goodies...
  23. Have you noticed the date on this thread?
