34 pickup on an A frame ??
Discussion in 'The Hokey Ass Message Board' started by straightaxle65, Oct 24, 2007.
  1. straightaxle65
    straightaxle65
    I was looking at using a model A frame since I already have it to build a 34 pickup. This will just be an open fender ride and I plan on channeling it about 4 inches. Will this work ok or should I find a 34 frame? What are 33/34 frames going for these days?
  2. Mike B
    Mike B
    You're probably better off with a model A style frame/homemade frame because you're channelling it. The 34 frames are beefy for a channelled truck, but could be made to work.
  3. Stick Shift
    Stick Shift
    from LENA IL
    My 33 is on an A ch***is. The box and fenders are A also. The A ch***is is shorter than the 33 or 34 frame.
  4. fleetside66
    fleetside66
    My '33 is going on an A frame. I'll probably end up channeling it 3." I already chopped the cab 3." Jeez, I never realized, there's a lot of 3's going on here. I'm going with the stock "A" 103 1/2" wheelbase, because I want to avoid the stretched out look (just a personal preference). No suicide front end. I love the simplicity of the "A" frame.
  5. straightaxle65
    straightaxle65
    Thanks guys! Stick Shift, Do you have any pictures of your truck that you can post?
  6. Stick Shift
    Stick Shift
    from LENA IL
    Ask and you shall receive. lol I was messing around last sunday and took these.
  7. straightaxle65
    straightaxle65
    Thanks Stick Shift, I like the stance!
    I can't believe you committed the ultimate sin and painted a fake name on the door when it was probably not a real shop truck in the first place!!!! Oh the Humanity !!
  8. Stick Shift
    Stick Shift
    from LENA IL
    Oh so bad, so sad i guess. Bad boy Bad boy. he he he he hehe he
  9. My 33 is going on a custom frame, but same width as a-rails. Going for stock wheel base also.
  10. purple
    purple
    My friend is doing just that, a channelled and chopped 34 on an A frame. His his an A bed that he shortened 9" I think. It is SWEET.
  11. primopro
    primopro
    from Corona, CA
    buy a set of american stamping 32 rails and build yourself a highboy pickup, you will be much happier and more comfortable, unless you are a midget.....
  12. Lono
    Lono
    So dude!
    did you build it?
