Mechanical aptitude test
Discussion in 'The Hokey Ass Message Board' started by barry2952, Oct 26, 2007.
  1. Dreddybear
    Dreddybear
    84. Me=Sort of smart kinda
  2. ****, 78%... it was the pulleys and the electrimalicity
  3. nailheadroadster
    nailheadroadster
    84 for me. I'll admit, I'm not too sure where I got em wrong. I know I gave an "educated" guess on the planetary gears though. Honestly, it probably wasn't too educated, but I didn't just guess either.
  4. failed with 74 and 370 points ,but some things i did not understand because my bad english
  5. DrJ
    DrJ
    I got a 92% but failed to find an itemization of which questions I missed.
    Was there one?
    I may have screwed up on the ones that use terms that aren't used in physics, like "deceleration," there just ain't no such thing.
    A physicist would call it an acceleration in the opposite direction just as a turn is an acceleration in a lateral direction to the current acceleration...
    And friction isn't what makes brakes work. An exchange of energy in the form of heat is what makes brakes work - to a physicist.
    But some of terms like these are used in mechanical sciences... :rolleyes:
  6. pitman
    pitman
    (94) and I was gunning to beat Squirrel!:rolleyes:
  7. falconizer_62
    falconizer_62
    there was a ****on, forgot what it was called, where you can go question by question and it will tell you which ones you missed.
    i got the planetary, the worm gear and the fan wrong. on the fan i thought direction was relative to the front of the fan, but oh well....
  8. tootallrodder
    tootallrodder
    I go an 84 also, I agree with wanting to know what I answered incorrectly. But it has been along time since applied mechanics and physics in school.
  9. squirrel
    looks like Liv42day is the one to beat at this game :)
    When taking tests in school, I always figured that anything over 85% was gravy
  10. DrJ
    DrJ
    So which answer is correct on the fan?
    It's going to turn the direction it turns when ON itself because of the angle of it's own blades, but that doesn't have anything to do with which direction they are referring to as same or opposite in the question setup.? :confused:
    A case of a dumb question failing the testee.
  11. 68% here, the electrical stuff killed me.
  12. chevnut
    chevnut
    from Corona, Ca
    My score made me think to stop what I was doing in my garage and stick to bodywork:eek: Unless there is a test for that too that I can fail.
    I **** more than McPhail..ok maybe not that bad...:)
  13. Sinner
    Sinner
    88 here.
    The pulleys were driving me nuts.
  14. 49ratfink
    49ratfink
    86% ... I need to go back and take it again so I can check which ones I missed...
  15. Plowboy
    Plowboy
    84 here as well
  16. rusty48
    rusty48
    I got 82,had to guess at some of them.
  17. BPDRacing
    BPDRacing
    94% Reminded me of the mechanical section of the ASVAB I took to join the Air Force...but I got a 99% on that one.
    I think the pulleys may have tricked a little but I did not know about the ****on on the left and I don't feel like taking the test again.
  18. squirrel
    everyone who takes the ASVAB scores above average! Uncle Sam wants YOU!!
    (but yeah, 99 is pretty good)
  19. Tin Can
    Tin Can
    gosh, I **** I failed. Need to learn the electrical schematics
  20. swade41
    swade41
    from Buffalo,NY
    I'm glad they don't require this test when you go to the parts store to get your parts, my **** would never get built.
  21. Wesley
    Wesley
    86, I did better than I thought I would
  22. pitman
    pitman
    Must be we're a bunch a those durn injuneahs! :eek:
  23. TudorJeff
    TudorJeff
    I wasn't going to reply, but I saw where some mechanical engineer also got a perfect score. (I'm an Industrial Engineer)
    Either way, I thought the test was cool and I sent it to a bunch of my co-workers. Thanks to the person who posted it! -Jeff
  24. 55 dude
    55 dude
    74%! after taking that test and reading some of the results have i got a deal for you! get your christmas shopping done early, 2 for 1 offer ELECTRIC DOG POLISHERS! call in the next 10 .........
  25. I gots me a 94%
    pulleys and governor got me.
  26. Bondobob
    Bondobob
    I got a 90 and my boss a 94 so now I know why he's the boss!
  27. Spyder
    Spyder
    from Houston
    86, I can live with that. The pully section make my head hurt.
  28. Kamp
    Kamp
    from Peoria, IL
    94 for me. Messed up the gear reduction / overdrive equation & multiplied when I should have devided. Other one was a lever one I misunderstood - thought the arrow was where you were supposed to lift, not the pivot - duh...!
    Kamp
  29. Liv42day
    Liv42day
    It so happened that I enjoyed the pulleys and almost switched from Mechanical to electrical engineering during school!
    Again take a look at the ****on to the left of the submit ****on. It pulls up the table of contents and shows a green check for the correct ones. I did not head back for a wrong one.
    Fully enjoyed the test though. P***ed it along to others here at work.
  30. iracer
    iracer
    90%, screwed up the planetary gear question, they always confuse me. I then argued semantics with a couple of the physics questions. For being a mechanical engineer I was surprised I nailed all the electrical questions. Not ready to switch to being a sparky.
