Tech - Can you ID this tool
Discussion in 'The Hokey Ass Message Board' started by daveheld, Oct 28, 2007.
  1. daveheld
    daveheld
    I'm looking for the proper name for the tool used to form the metal as shown in the following photos... This tool was quite handy and it only took 20 - 30 minutes to form 17 holes - but it took a few hours to make the tool !
    If anyone sells such a tool, I would like to purchase others... Now I have one for 1 1/2 diameter holes, but not all sheet metal holes will be this size...
    email dave@team321.com if you know where to purchase these...
  2. daveheld
    daveheld
  3. jerry
    jerry
    Dimpler?
    jerry
  4. donzzilla
    donzzilla
    Greenley (SP?) electrical knock outs do basically the same thing. You drill a small hole put the two pieces together and tighten them down. They also have fancy hydraulic ones too. I don't think it would be hard to modify them to roll the edges of the hole to get the effect that you want.
    Hope this helps, Don
  5. daveheld
    daveheld
  6. leon renaud
    leon renaud
    from N.E. Ct.
    They were called flanging dies at the machine shop I worked at.I don't know if thats a true name or just what they were called there
  7. auggiestyle
    auggiestyle
  8. docauto
    docauto
    from So Cal
  9. stealthcruiser
    stealthcruiser
    Lightening hole punches,and also belling dies.
  10. Drag'n 59
    Drag'n 59
    from DALLAS, TX
    I second the Flange Die
  11. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    Belling tools are what I always heard them called. Been around for years, the type you have make "bells" the metal to the angle of the punch the ones that I have make a much deeper bell and are easier to make as you only have to cut diameters not angles. I think that the bell or flare also adds more stiffness. I am attaching a picture of the tool and the belled holes on an aircleaner that I made.
    Rex
  12. Reverand Greg
    Reverand Greg
    Dimple die according to every old cat Ive every worked for
  13. HHRdave
    HHRdave
    from So Cal
    They are called "Dimple Dies" in the aircraft industry, and you can buy them seperately or complete sets, just do a Google search. I'm sure its cheaper to buy one than your time to make one.
  14. mykwillis
    mykwillis
    i've always called em dimple dies.
  15. barry mazza
    barry mazza
    Belling dies , yes, they ain't cheap, www.tricktools.com......I made one yrs ago out oak on a wood lathe. Only used it for 2 friggin holes then, never again.
    BARRESSE'
  16. TomWar
    TomWar
  17. KIRK!
    KIRK!
    Did you notice that this thread is three years old?
