Henrob or Victor torch?
Discussion in 'The Hokey Ass Message Board' started by Garage Concepts, Oct 30, 2007.
  1. Garage Concepts
    Garage Concepts
    Looking in to getting one pretty soon, Just wondering what everyone is using these days?
  2. Redneck Smooth
    Redneck Smooth
    from Cincinnati
    Meco Midget! The same great tiny flame as a Henrob without the 5lb weight or high cost. I can hold a puddle on 18g almost indefinitely with mine and I'm fairly new (2 years) to gas welding. Only $115 at tinmantech. You need to buy some adaptors to put it on a normal hose and use decent regulators, but my local welding supply store got me the adaptors for $10 or so...
    http://tinmantech.chainreactionweb....rch.php?cart=d413412cb06d43214f8d1a814399c306
    And a thread of what a motivated HAMBer can do with one with a little practice...
    http://www.jalopyjournal.com/forum/showthread.php?t=145993
  3. HENROB,
    hey its Australian!
  4. Mike Rouse
    Mike Rouse
    Meco Midget, like Redneck said. Get the superflex hose set and a 2 stage regulator set and you will be in control.
    Mike
  5. poop
    poop
    The Dillon/Henrod is weird to hold but it has less flame pressure, since it mixes the gas and oxy in the handle rather than the tip.
    Try both and see what works for you.
    Good luck
  6. chopolds
    chopolds
    from howell, nj
    I've got a Henrob, never tried the Midget.
    If you don't have a plasma cutter, and don't plan on getting one in the future, get the Henrob. The Midget doesn't do cutting, the Henrob is excellant at it.
  7. Creepy Jack
    Creepy Jack
    from SoCal
    I have a Victor, a Henrob, and a Meco Midget. I like the Meco the best. Small, really light, very easy to handle. The Victor is just your run of the mill torch. The Henrob does everything that it's advertised to do, but is awkward because of the shape (IMHO), and is also very heavy when compared to the Meco.
  8. joeycarpunk
    joeycarpunk
    from MN,USA
    I second that, I love mine.
  9. Reverand Greg
    Reverand Greg
    With a Victor you will never be limited,I can use mine to braze your sun gl***es or cut 1 1/2" plate.Victor is the industry standard
  10. Redneck Smooth
    Redneck Smooth
    from Cincinnati
    I have a victor as well as my Meco. Industry standard or not, they don't make a tip small enough to do sheet metal as well as the Meco. I agree that they make quality stuff though...
  11. Garage Concepts
    Garage Concepts
    Well I was hopping you guys like the Victor one b/c I been working up a trade with this guy, he's giving me a brand new set up (Victor Brand) for some hydraulic pumps I have in my garage. Should I just tell him to give me the cash and get a Henrob?
  12. Mike Rouse
    Mike Rouse
    I also have the victor j48 (I think that is the umber) it is the aircraft torch.
    It works great on sheetmetal with a OO tip. It has the valves up at the top of the handle.
    It is just a little heavier than the Meco.
    Mike
  13. Bluto
    Bluto
    I have a bunch-0-torch collection
    Yes they are heavy and dumb but nothing welds sheet metal like a Henrob
  14. CAS
    CAS
  15. maxspeedracing
    maxspeedracing
    Meco Midget. Get the small hoses too.
    Caution: the meco doesn't use gaskets on the tips. If you don't tighten them down with a wrench, then you will get a big surprise.
    Ask me how I know --- YeeeooooWW!
    I have a Henrob and a Victor as well. I like them all, but love the Meco.
  16. maxspeedracing
    maxspeedracing
    Get the cash, buy a Meco, the Hoses, and the TM2000 lens in the headset, and some flowers and dinner for your girlfriend.
    ...or spend it all on a Henrob.
  17. Garage Concepts
    Garage Concepts
    Can i use the Meco Midget on a victor system, and just switch out the torch with proper hoses?
  18. Reverand Greg
    Reverand Greg
    get a small tip and make a new screw on tip for it and drill your own small hole.ten dollar tip five dollar fix
  19. Redneck Smooth
    Redneck Smooth
    from Cincinnati
    I guess it depends on your regulators, see other threads. But, honestly, I've used mine with both good regulators from Harris and cheap chinese ones from Harbor Freight (second hand, I know better at this point than to spend money there) and it works fine. I just needed a pair of adaptors from my welding store. Cost less than $10. The hoses are nice because the torch is so tiny that big hoses make it feel kinda off-balance, but it works for me...
  20. Redneck Smooth
    Redneck Smooth
    from Cincinnati
    I don't understand what you're talking about here. How do you drill your own small hole when all the tips they sell for that torch have a bigger hole than the one you need to easily weld thin sheet? I think I could weld up a pop-can with my Meco...
  21. Bluto
    Bluto
    On my tiny torches I use TIG water line for hoses. been doing that for years...... you can't step on them but they are light and work well
    The smallest torch rig I have is a Victor jewelers rig with it own hoses
    There is a Smith rig even smaller than the Meco but I still go back to the Henrob.
  22. grail21
    grail21
    from Salem, MA
    How thick can you weld with either the Meco or the Henrob?
    1/8" - 3/16" - more?
  23. Creepy Jack
    Creepy Jack
    from SoCal
    I've welded up to 1/4" with the Meco. The Henrob is reputed to weld up to 1/2".
  24. grail21
    grail21
    from Salem, MA
    1/4" is plenty strong for any bracket I'd be welding on my bike (jumping over here from the Jockey Journal). Thanks for the info Creepy.
  25. torchmen49
    torchmen49
    Just come inside for a break (chopping a '51 Merc 4 door) and noticed this post. I have to say personaly I like the Henrob/ Dillon/Cobra. I'll admit I haven't used a Meco. The size, and weight ? of the Henrob isn't really of concern tor me, you weld an inch, then hammer and dolly anyways. I like the fact that the torch has an incredible mixing chamber compared to Victor, very little unburnt acetylene, resulting in a flame comparable in size to a pinstipe brush quill = LESS RADIANT HEAT. I invested in a Gas Saver shut off valve. I mounted it on a microphone stand bought at a garage sale. Weld a little, hang the torch(torch shuts down), hammer & dolly, pick up the torch (gas flow starts up again), light the torch with the pilot flame, and "Bob's your uncle" . My two cents worth.
  26. Creepy Jack
    Creepy Jack
    from SoCal
    Yep. Get all the tips that Kent offers. You're gonna need 'em eventually.
  27. Redneck Smooth
    Redneck Smooth
    from Cincinnati
    Awesome, I've got my Meco on a cymbal stand. Same thing basically. The gas saver's the best $50 someone who wants to O/A bodywork can spend...
  28. Reverand Greg
    Reverand Greg
    all of my tips have a screw on end that can be removed,a replacement tip fabbed up with a very small hole I started at .050 and reamed it out until I got an even flame about the size of a pencil lead and 6" long
