1940 ford sedan deluxe frame questions
Discussion in 'The Hokey Ass Message Board' started by jscott183, Nov 2, 2007.
  1. jscott183
    jscott183
    from Fox Ok
    Hello i have a 1940 sedan. ive heard of people putting these on s-10 frames. i was wondering if it would fit on a ford ranger frame instead. i have a 86 ford ranger with a 302 in it and id like to use that frame and engine in this car. any help or advice anyone can give me?????:confused:
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    I have yet to see a frame that cant be repaired.
    I'd advise you to fix what you have. The stock suspension and handling on these cars are almost as good as any independent setup.
    Marry an old body to a new suspension and regardless what you do. You never can manage to hide it. More work than you can imagine.
  3. Deuce Roadster
    Deuce Roadster
    Like PeteJoe says ...
    Keep the 40 frame. You could use the Ranger rear end under the 40 frame and install the 302 and transmission from the Ranger also.
    The Ranger could be a good " donor vehicle "
    Giving up the engine, transmission and rear end for the 40. A lot of the other small stuff MAY WORK also.
    :D
  4. Ya, What they said. It's a big job and if you half to ask a blanket question about doing it you probably shouldn't take it on by yourself. If your starting with Junk and just building a Klunker where fit, finnish, and Quality don't matter it could be a good learning experiance. Having done Multiples of this kind of "Stuff" for Customers (I get paid for doing it there way) I'd never do it for myself.
    The Wizzard
  5. Cruiser
    Cruiser
    jscott183,
    The guys are right forget the any frame swap, follow their advice and you'll do just fine.
    CRUISER :cool:
  6. put it on the Ranger frame , perfect fit...and it's easy and cheap to do
  7. alchemy
    alchemy
    Careful 3-window, he may think you're serious. And they ain't making 40's any more.
  8. jscott183
    jscott183
    from Fox Ok
    Thanks. i think the frame is salavagable just wanted to know if i had options besides buying a new frame. i know the floor boards are shot but i think for the most part the frame is still usable. appericate all the help guys. later
  9. Don Spear
    Don Spear
    from ma.
    box the 40 frame
  10. 40Standard
    40Standard
    from Indy
    I'd stay with the stock 40 frame, go with a straight axle or mustang II
