Was up getting the car paited till 2 this morining. Turned out so great. It is the Kustom Flatz Copper Pearl. THis stuff was awesome. Check it out!!! Now onto the Mustang II install and the Roush rear end install with 4 link. Hope she'll be driving by spring!!! After the first layer
Thanks. There are just no springs in it right now and the rear is blocked up. Gonna be bagged in the front with the Fatman Mustang II front clip and the rear will be 4-linked and bagged as well. Should be pretty close to sitting the rocker on the ground!!!
How does the flatz react to wet sanding and buffing; does it still retain the flat look after being buffed out ?
I didnt sand it or buff it out, so I don't know. No need to sand or buff it since it isnt being cleared. It is just basically a single stage flat paint.
