Welders I picked up
Discussion in 'The Hokey Ass Message Board' started by CG, Nov 3, 2007.
  1. CG
    CG
    Ive been in the market for a welder. Read a ton of threads here on em. I was ready to buy and then Ryan posted the thread about possibly getting discounts from Miller. Nothing seems to have come about yet though.
    My neighbors are retiring, selling their home and going to live in their motor home. He asked me to come over one night after work, he said he had an offer I couldnt refuse. Well he offered me up a large package deal on all his shop type stuff and a couple of his rigs (not HAMB type rigs) and it was too good to p*** up.
    These two welders were part of the deal. The little mig is a flux core welder, I know those have mixed reviews here. I think between these two I should be able to do pretty much anything Ill ever want to do with building a car.
    For those of you that have these particular welders, do I need to even bother with getting a newer Miller now?
  2. sawbuck
    sawbuck
    from 06492 ct
    nice score,you are gonna want gas for sheet metal work.does that flux core have a hook up for gas?
  3. CG
    CG
    I honestly dont know. There is a cut out on the back side that looks like a bottle could be put in there. I need to look up the specs online.
    Its a Campbell Hausfeld fluxcore 80.
  4. Lincoln crackerbox. Have one myself. Great for making trailers and the like. Probably the most sold welder ever.
    It is not as good as a Miller Bobcat, etc. (AC only, no DC), but it works fine for a me.
    Tony
  5. pasadenahotrod
    pasadenahotrod
    from Texas
    More hotrods ch***is have been welded with Lincoln 225s than any other welding machine...ever.
  6. 1931S/X
    1931S/X
    from nj
    an old tombstone. tried and true. they made 7018 just for machines like that. 80 amps isnt to bad for most car stuff, but how many heat settings does it have? if its only got say hi and low for the heat, i dont think is put any money into it.
  7. guanoLoco
    guanoLoco
    from tuson, az
    a lot of those little C-H welders are plumbed for gas. just make sure to reverse the polarity if you switch from flux to mig. if you dont the welds are still gonna look like they were done with flux core.
  8. Shifty Shifterton
    Shifty Shifterton
    Yeah, you still need a welder. Only now it's a TIG
  9. jusjunk
    jusjunk
    from Michigan
    Ive built 4 cars using a buzz box like that.. If you can weld at all an arc welder will do most anything. At one time I had an early lincoln ac dc machine but I had to sell it after my divorce but I see it every day cause the company I work for bought it ! That was a good welder and it had a real copper wound transformer. Took a cherry picker to load it in my truck !
    Dave
  10. 1931S/X
    1931S/X
    from nj
    sounds like an idealarc
  11. 55 dude
    55 dude
    those will get you off and running. if that c-h machine won't run solid wire sell it because the lincoln will do any ch***is work you want. ac welders run fine but usually not as smooth ac dc machines,ac machines have more flare at the arc. one thing i did do when i wire up my compressor and welders i made sure all the plugs were the same. what are you building?
  12. Don Spear
    Don Spear
    from ma.
    the flux core welder will leave a weld with pock holes in it. Ok if you are going to grind down the weld. The lincon buzz box was a welding staple in my days. every roundy round racer had one
  13. Skotz
    Skotz
    I still have and use my ol Lincoln welder that I bought in the 60's...built lots of stuff with it and more to go, though I am spoiled by newer stuff that I have in the shop.....still can't get rid of it:) .
    Skot
  14. sko_ford
    sko_ford
    is it true that on that buzzbox all you need is a torch and regulater and you can tig with them?
  15. kenagain
    kenagain
    from so cal
    hey the man is the welder the box is the tool good welder can make em both work just need to practice n get good at it
    I got a harbor freight flux wire welder that i reworked n it works ok on small stuff if I run it a little hot n fast no welds should ever need to be ground down unless going for flat panel finish and not structural
    my 2 cents worth
    Ken
  16. flatheadgary
    flatheadgary
    from boron,ca
    that lincoln was the first welder i ever bought back in '71. it built probably about 35 cars since then. the one thing nice about that welder is, if you need to do a small weld, you can use the small rod and if you need to weld something like 3/8 plate, it will do that too. unless your really good, most welds will need to be cleaned up a little just for looks. i have a 255 lincoln tig and a 285 mig and they will weld just about anything and thickness but when i want serious weld penetration, i use that buzzbox.
  17. CG
    CG
    Thanks for all the comments fellas. I have a bunch of old frames and a bunch of old truck doors. Ill just drag em home and start practicing.
