371 Olds internal balanced
Discussion in 'The Hokey Ass Message Board' started by T2Vracing, Nov 7, 2007.
  1. T2Vracing
    T2Vracing
    from Arivaca
    Looking for someone who has found a good zero balance dampener for the 371 Oldsmobile. The car is a internal ( zero balance) balanced engine , has Al flywheel and currently a 52 1 groove crank pulley. I wondered if anyone has made found etc.. a modern dampener that can work?
    Thanks
    T2vr
  2. mecutem
    mecutem
    I am not aware of any dampner that will do the job. I did read an interesting article in a 1957 rod book on how they added plate steel to the 371 crank to get the balance internal balance. They were putting a 371 crank in a 324 motor. Steve
  3. GOATROPER02
    GOATROPER02
    from OHIO
    Hi Owen
    We have one we have been working on just didn't advertize it yet
    Tony
    Ross Racing Engines
    Niles,Ohio
    330-544-4466
  4. DON_WOW
    DON_WOW
    For all aspects the 56 324 is all most the same as the 371 minus the lump that makes it match the 371 external balance. The difference is that it is a little shorter as to the depth it slides over the crank. A spacer put on the crank to allow the 56 to slide up to it would get you to the same spacing so the double pulleys are in the right line up with the water pump pully and its a done deal. Inside, outside is the same , so it fits the crank same as the 371 ,,double pulleys are the same,,,only the 56 is zero balance. easy solution.
  5. DON_WOW
    DON_WOW
    OR you could go big bucks and order a Fluidamper for a 455 interal balance , space the water pump and ect. to match and go from that angle.
  6. T2Vracing
    T2Vracing
    from Arivaca
    Thanks
    I'll measure the clearance to the front cross bar and see if a 455 can go on it.
    Thanks
    T2vr
