What should i expect to pay?
Discussion in 'The Hokey Ass Message Board' started by MrManz, May 9, 2004.
  1. I am going to have some Zoomie headers made for my Y block. I have the exhaust flange plates already. I want the pipe to be 3 ft long, cut at a 45 degree angle at the flange. Then i want them to have a 120degree bend and go straight. So they will end up pointing almost straight up. What do you think a header shop might charge for parts and labor on that?
    -Andrew
  2. hunter lake
    hunter lake
    A friend of mine had a pair custom made for his 28 dodge with a studee motor for $400.00 here in portland .....
  3. Holy ****. For a set of Zommies? If thats the case, ill probally just make them myself with my ****ty welding ability. Thats insane.
    -Andrew
  4. DrJ
    DrJ
    Buy a header kit for your engine with stubs already welded in the flanges and put the elbows together however yo want them. Just remember, if the outlets are higher than the inlets, sooner or later someone's gonna fill it up with "water" on ya and ruin the engine....
  5. AHotRod
    AHotRod
    Andrew,
    Do you have a mig welder?
    Do you have a hack saw or cutoff saw?
    If so, you can order exhaust pipe that has bends in it from the Mail Order kings, or take your pattern made from a piece of clothes hanger to a exhaust shop and have them bend 8 tubes up for you.
    Make your own set for $100 or so.
    Glenn
