ok what to do buy droped i beams? for $600! build droped i beams? any one evere done this is it worth it? stub the frame? what works best? or is z the stock frame and option?
I got a 66 and just the other day I was wondering this very same thing, can the I-beam be dropped like an early axle? and I was wondering if there was anyone on the hamb who had a jig or knows how to do this sorta thing to where the axles ain't all messed up I drive mine everyday and don't really want to be without IFS
I don't think there is a cheap way out of it? Dropped I beams or dropped stub axles it's all going to be expensive. I got mine down 3 inches just by putting lowered springs in it, but if you want it slammed then a mustang or jaguar front end is the go?
guy in cali has a little something in the works for the 67-72's. same deal, not sure if the frames are identical though.
the 65 my friend i did we lifted it actually. we raised it about 4". we did a relief cut on the i beam to be able to bend it and then welded it up and plated them in the length of the I beam on both sides. damn truck never wore the tires, he got about 45000 out of a set of BFG Mud terrains no less. my cousin has a 65 shorty that is at my shop that he paid close to a grand for the same lift, they just bend the stock i beams and you give them yours as cores. its not that hard to do you just have to do the math, and make sure your angles are correct , as where you want the truck to sit.
hes just got started on it, but the guy does top notch work. i dont want to say too much.....as im not sure exactly what hes doing other than hes working out a drop for these trucks.
Just got a 65 short bed for my son. Here's a place that has dropped beams for a lot less than $600 if you can sort through all the pimp my whip ****. www.truckn-store.com We have a stock 53 F100 axle that looks to be close to the right size for replacing the twin beams. I was thinking about getting that one dropped. If anybody starts dropping the twin beams we would be interested.
Take that twin I beam, cut it off and throw it in the trash. Here is mine with an 78 Pontiac Grand Prix front clip. Done in a weekend. And, my old 68 "back in the day" (79 Olds Cutl*** front.) Good luck, -Abone.
