Glass Bead Blasting Media
Discussion in 'The Hokey Ass Message Board' started by C9, Nov 13, 2007.
  1. Can you buy this stuff locally?
    In most towns in other words or is it something you need to order.
    How does it work with an HF sand blaster?
  2. SinisterCustom
    SinisterCustom
    I can get it locally....Kleen Blast.
    But the stuff is nasty......it breaks down easily and gets dusty, which is basically very fine gl*** shards, so were a respirator.
    I prefer copper slag.....lasts longer, is cheap and not as dusty....
  3. Digger_Dave
    Digger_Dave
    Jay, gl*** bead media should be available in most larger cities.
    Like SinisterCustom says, ... Kleen Blast is one brand.
    But as he says, "... the stuff is nasty......it breaks down easily and gets dusty, which is basically very fine gl*** shards, so wear a respirator."
    If you plan to use it in a "vented" - sand blast cabinet, ("dust" vacuumed out with a filter) it will work.
    Out in the open - VERY messy; and can get expensive.
    Proper gl*** bead cabinets re-cycle the beads.
  4. panheadguy
    panheadguy
    from S.E. WI
    The gl*** bead breakage is probably related to too high air pressure. We do beading every day and it lasts a long time. You do get allot of dust but is more likely to be broken down material being removed than the gl*** beads.
    PanheadGuy
  5. panheadguy
    panheadguy
    from S.E. WI
    As for obtaining the gl*** beads; look in the yellow pages under "metal finishing" You can order it but the shipping will be more than the beads.
    PanheadGuy
  6. Not2low
    Not2low
    from Eaton,Ohio
    I have been looking for pressure setting requirements for different media.Do you have such a list or can you tell me where I can find more info.Thank you.
  7. TudorJeff
    TudorJeff
    Good advice from everyone so far... Another thing to keep in mind is that your air supply needs to be super dry and you will need a considerable amount of CFM, not just psi. Good Luck!
  8. BenW455
    BenW455
    My local Tractor Supply co. has blasting media. Also most welding supply places have blast media. Tip tools has a good selection of media but shipping my be high.
  9. What I'm trying to do is clean up a pair of old slot mags.
    Sanding, 3m pads & buffing are doing it, but the backsides and slots just need to be clean.
    Sandblasting looks like it may work ok.
    The 5 1/2" wide front wheels on the 32 were dull and the slot's polished.
    When I got em back from the chrome shop where they polished them the wheels were nicely polished and the slots dull.
    An ok look, but polished slots and wheel would have been nice.
  10. mtkawboy
    mtkawboy
    Welding supply shop
  11. brownbagg
    brownbagg
    from grand bay
    I get mine from Grainger
  12. 53chieftian
    53chieftian
    Spill 'em on the floor and its like walking on a million little marbles!
