I need some of you Ford ch***is experts to help me ID the frames in the pictures. The red one was under my '39 coupe. It was removed when I installed the body on the black frame. It's time to order a radiator and just want to make sure I have the correct info to give to the shop. My question involves the radiator mounts in the front of the ch***is. The mount on the red frame is paralell with the lower frame rail. Notice the one on the black frame. It's raised up about 2" above the lower frame rail. I would like to find out what year these frames are. Any of you Ford experts have any opinions as to the years of each? Any help would be appreciated as I don't want to order a radiator and then find there is something I overlooked. Thanks, Mike
the radiator mounts on the red frame are for `39 deluxe and all `40's you need to transfer them to your black frame so you can use the radiator made for the `39 deluxe you have in your profile FYI...the mounts on the black frame were used `36 to `39 standard
I have a supposed checked and good original 37 radiator that I bought years ago that I would sell you if youre interested. I am going to Florida to the Turkey run in a few weeks too. PM me if your interested.
Wow..that was quick! Thanks a ton for the great info. Guess I need to go grind on more of Henry's rivets... Appreciate the help, Mike
the Wescotts frame drawing on their website has details of each of the 3 types from 35 to 40. 41 for trucks only
I used a 31 radiator in my 40 pick up it gave me 3" more room for my 302. I did'nt have to cut the fire wall.
With a bit of cutting, the '36 frame is now ready for a '39-40 radiator. Worked out fine. Thanks for the info guys. Mike
