Another model A coupe build post!
Discussion in 'The Hokey Ass Message Board' started by titus, Nov 3, 2007.
  1. titus
    titus
    well, i had all this left over model a coupe body panels that i got for next to nothing but what was left was next to nothing, it was partially an old dirt track body with some other chunk of another car, well i had enough parts laying around to make a complete body, kinda--the whole bottom of the car is gone so im gonna have to patch all that up but should be fun.
    so i did some measuring and made a frame two weekends ago, then i got the body kinda in one piece, chopped it 6-1/2 inches, then i got that on the frame.
    the other day i fabbed up the subrails and got the rear end ride height figured out, so then i got the front mocked up at ride height, then i swung the hemi into place for fitment, everything seems to fit rite so far, im gonna wait on the front end/wheel base placement till i have the pully system and rad there for measurements, i dont want the grille to far forward of the wheels.
    then last night i did some reinforcing of the body, 1x1 tubing around the back window, some around the quarter windows and then around to the back panel, then down to the subrails, its getting very sturdy.
    it also needs some major rear quarter drip rail repair, i think i got it all figured out in my head what i want to do with that.
    stay tuned for more
    same bat channel
    same bat time
    ***us
  2. titus
    titus
    the motor is an industrial 331 with the high mount water pump, i looked into a few tech things here on the hamb, maybe some one would know, the water pump on there is super long, is there one that is shorter that bolts in the same place, i have some ideas of leaving the timing cover along and making an idler/fan set up like a flathead but need a shorter water pump??
    i have a couple of water pumps ordered in to work on monday but am not sure if theyll fit, one is almost identically looking to the one i have on there but is shorter, catolog says it fits 51-54 chrysler industrial so im hoping!
    jeff
  3. 31whitey
    31whitey
    nice work man
    car looks real good
  4. amsvette
    amsvette
    Keep the pictures coming! That's not too far off from what I'm starting with, perhaps you will be my inspiration this winter.
  5. hiboy32
    hiboy32
    from Omaha, NE
    that is bad***!!! I want to see more progress. This is inspiring. Damn you always have the coolest projects.
  6. Stick Shift
    Stick Shift
    from LENA IL
    Dang it. Two months left in this year. You will probably taking it for a spin New Years Eve too. KOOL
  7. towaholic
    towaholic
    from Rogers, mn
    ok stop what you are doing and let me know what you want for it right now? that ****ers sweet .
  8. McKee
    McKee
    Whew! that's gotta be tight?
  9. pecker head
    pecker head
    Dang ! I like it . chopped coupes rule !
  10. dr_amx
    dr_amx
    Right on!
