Need help choosing carbs for stovebolt
Discussion in 'The Hokey Ass Message Board' started by Mockie, Nov 21, 2007.
  1. Mockie
    Mockie
    I recently bought an Edmund's dual carb intake for my 235. I'm obviously not a knowledgable carb guy, need some advice on what carbs to get. I have a rebuilt rochester on the stock manifold now, seems to leak pretty consistantly, anything better out there? Also,motor has a 3/4 cam and is .60 over if that is useful. thanks to all.
  2. hsheartaches
    hsheartaches
    Maybe some Holley 847's?? I'm not too knowledgable in the 1bbl carbs. Somebody will chime in.
  3. Mockie
    Mockie
    no carb pros on yet?
  4. hsheartaches
    hsheartaches
    Who did the rebuild on the carb?? Rochesters don't normally leak consistently like that unless it's installed improperly or the float is hanging up. Have you checked out what Vintage Speed stocks in the 1bbl department?
  5. 6inarow
    6inarow
    I have found rochesters to be a pain in the ***. email me and I can give details if you like.
    Carter's are good carbs - www.thecarburetorshop.com or www.vintagespeed.com for info on Holley 847's (even though he doesnt have such a good rep - do a search here first).
    some of those intakes had 3 bolt carbs and some had 2. so that will determine the carb.
  6. PBRmeASAP
    PBRmeASAP
    are you serious????? they leaked from the factory! great carbs to use on multicarb intakes, but they leak just a little
    but carter W1's are not bad either
  7. xderelict
    xderelict
    Carter yf is another that came stock from chevy.Good carbs and kits are available.Watch for differances between 216,smaller bores, and the 235 versions.Not had much luck stoping one rochester from leaking let alone three.
  8. gear jammer
    gear jammer
    from tucson az
    stromberg boxv2's were the choice carb for multible 1 BBl applications, similar to a 97, there the best, there worth looking for, have fun
  9. Flop
    Flop
    the bxv 2s are the ****. running 2 on my 216 with the adjustable high speed jets .tuned them once and havent touched them since and it has been about 6 months no leaks no problems what so ever and wow did it help the performance
    found these 2 on ebay for 40 bux a piece Nos still in the box with all insturctions and gaskets and electric chokes which is very nice!!
  10. Taff
    Taff
    be interested in this as well, it's one of the planned "to do's" on my 235
  11. Mockie
    Mockie
    found multiple carter w1's on Ebay, I need something with a 2 bolt pattern 2 15/16 ctr-ctr, not sure what all will work.
  12. Flop
    Flop
    wait to find those strombergs you will be very happy
  13. 22dodge
    22dodge
    from Nevada
    Like they have said previously, I run Stromberg BXOV-2 carbs, both 2x1 on an Edmunds and 3x1 on a McGurk.
    I put the Rochesters on a shelf 2 years ago, no regrets. :D '22
  14. cruisinkruty
    cruisinkruty
    Ya want reliability?Performance,adjustability,Go with a Rochester Monojet 1MV as found on 1975 and up 250 Chevy sixes. They fit have linkage similiar to the OLD skool rottenchesters and work great as parts are available and cheap,check Egay out. They have modern Nitrophyl floats and needles and seats that do not leak. :D
  15. PBRmeASAP
    PBRmeASAP
    word of warning on W1's.....they made about 1 billion different setups....and it's hard to get a matched pair.
  16. Mockie
    Mockie
    sorry to keep bringing this post up, but really having trouble finding any of the carbs mentioned. also don't really think I got a straight forward answer as to if all of the carbs mentioned will fit 2bolt pattern X 2 15/16 ctr-ctr. Thanks to all. Just new to the carb stuff and want as much info as possible.
  17. PBRmeASAP
    PBRmeASAP
    Bumping this back up....
    seems sixstring never got his answer......carter W1's are (****py) 2 13/16"
    Rocherster B or BC's are 2 15/16"
    Anyone know what the stromberg BXOV's are? also what did they come off originally?
  18. 6inarow
    6inarow
    Email Flop - he knows the BXOV's.
  19. HEATHEN
    HEATHEN
    from SIDNEY, NY
    BXOV-2s have a 216 bolt spread. Stromberg made a similar design carb with the larger 235 bolt pattern, but I can't recall the number.
  20. Flop
    Flop
    i wonder if it is bxuv for the 235
    also the ones with the adjustable jet were aftermarket
    they were off a ton of cars i believe
  21. PBRmeASAP
    PBRmeASAP
    so i'd be safe to ***ume that the bxOv is for the 216 and the bxUv is for the 235? i'm getting ready to change intakes for the third time switching to a fenton and i'm ready to experiment with new carbs. I like the idea of the adjustable jet, just need to make sure it's the correct width cl to cl on the mounting....any help?
  22. Mockie
    Mockie
    thanks for some more help, heres a kinda ****py pic but a pic of the 235 I built and the intake I'm needing the carbs for.[​IMG]
  23. PeteFromTexas
    PeteFromTexas
    I'm running 2 Rochesters on my 235
  24. chris63
    chris63
    ok well i'm running three Rochesters on my 235 six and yes they did leak when i first put them on i found out that the floats have to be finely tune and get the extra thick gaskets that i found as new old stock at a carb shop and they are a bit tuff to keep in tune strombregs are the way to go from what i hear so when you learn which ones fit right please let me know and with the linkage
