olds 394 timing cover
Discussion in 'The Hokey Ass Message Board' started by aerorocket, Nov 22, 2007.
  1. aerorocket
    aerorocket
    from N.E. P.A.
    What modifications are necessary to run the lighter 63-4 timing cover- water pump ***embly on the earlier 59-62 blocks?
  2. langy
    langy
  3. DON_WOW
    DON_WOW
    None ,,it just won't fit---bolt pattern different.
  4. aerorocket
    aerorocket
    from N.E. P.A.
    I realize that the bolt pattern is different this doesn't mean you can't drill and tap holes as long as the block castings are similar. An old Olds guy told me there is a 30# weight difference between the cast iron and aluminum set ups. I don't mind doing some work, however I do not want to go through all the trouble of scrounging up an aluminum set up if it is going to be phisically impossible to adapt.
  5. yorgatron
    yorgatron
    what you need is a '63-4 "window" block.
    honestly,if you really needed to shave that weight you'd have gotten hold of a MOON timing cover.
    but the real reason you don't want it is they're all corroded terribly :(
    add to that the 2 year-only water pump is hard to find and expensive,and if the timing tab is broken off of your core they won't take it.
  6. not to mention the earlier pump & cover is way better looking!
  7. aerorocket
    aerorocket
    from N.E. P.A.
    Thanks guys I appreciate the advice.
