Which Elec Fuel Pump To Use??????
Discussion in 'The Hokey Ass Message Board' started by BBobb, Nov 25, 2007.
  1. BBobb
    BBobb
    I Have Decided To Use A Elec Fuel Pump Set Up In Front Of My 3x2 (rochester 2gc)on A Stock Sbc 350 Could Somebody Please Recomend The Proper Set Up From Fuel Line To Intake Including (psi) Upfront Thanks For The Help
  2. Sour Kraut
    Sour Kraut
    What's wrong with the mechanical? Besides the fact that it works and is reliable!
    If you must run an electric, DO NOT run it up front! Electric pumps are made to push and need fuel above or on the same level as the pump to work correctly. No more than 6 psi.
  3. bonesy
    bonesy
  4. man-a-fre
    man-a-fre
    Really had good luck with my mallory comp 110 running my 4 rochester 2g's performs flawlessly.
  5. moses
    moses
    holley close to fueltank
  6. fuel pump
    fuel pump
    from Caro,MI
  7. 38pickup
    38pickup
    I have had nothing problems with holley pumps. I say get a carter, they seem to just work.
