Stop the insanity!!!
Discussion in 'The Hokey Ass Message Board' started by HotRodChassis, Nov 28, 2007.
  1. HotRodChassis
    HotRodChassis
    Alliance Vendor
    Two more sets of headers from my warped mind. Be popular, tell all your friends you've seen headers built by the least famous person you'll ever know.
    These are on a Hemi powered '32 Plymouth PB Coupe
    And these on a '56 Cameo with a 348 W
  2. Doc.
    Doc.
    Those are beautiful Kev.
    Doc.
  3. AnimalAin
    AnimalAin
  4. Gerg
    Gerg
    you are ****ing insane....... i love the headers keep up the good work!
  5. Stick Shift
    Stick Shift
    from LENA IL
    Kool Must be hard to keep track of the tubes. lol
    Nice flanges too.
  6. wc chopper
    wc chopper
    you should call em medusa tubes!!
  7. rustbucket
    rustbucket
    from DFW Texas
    Beautiful work!
  8. Yo Baby
    Yo Baby
    That is a nice lookin' set o' pipes.
    Any particular reason the primary rat nest is so long?
  9. Wicked Nice Work!!! Building headers is FUN and will drive a man MAD. Again Nice work.
  10. eaglebeak
    eaglebeak
    They belong in an art gallery.
  11. Bob K
    Bob K
    from Antigo Wi.
    Beautiful work Kev, medusa, bundle of snakes, either would work for me.
    B:)B
  12. 31whitey
    31whitey
  13. hotrodladycrusr
    hotrodladycrusr
    ****, that does it....I see headers in Big Olds' future.;)
  14. LargeB
    LargeB
    That last set are AMAZING!
  15. 51Fourdoor
    51Fourdoor
    Perfect headers for those 348 heads!
  16. HotRodChassis
    HotRodChassis
    Alliance Vendor
    Believe it or not, the first set primaries are only 33" long. It's a Hilborn Stack injected 392. Brother, one thing I don't question is Ted at Opel Engineering. When Andy from Hilborn and Ted gave me specs that almost matched on the money for the tubes, that's what I built! I'm no parts matcher when it comes to engine internal anatomy, so I trust Teds' 40 years. :)
    So, in answer to your question (more directly), the '32 Plymouth has a 392 stuffed in between stock '32 Plymouth rails and it's fendered. So the headers had to be sandwiched in between the rail and the side of a Hemi, along with the starter and the steering shaft. Oh, and it had to end BEFORE the inner frame rail and also clear the lower control arm for the front suspension. I told the owner, "no problem." :)
  17. HotRodChassis
    HotRodChassis
    Alliance Vendor
    Denise, you're going to make me blush! LOL. Really, you'd let me pipe Big Olds? :)
  18. Bass
    Bass
    from Dallas, TX
    Equal length? And who makes the collectors you're using?
    Both sets look great!!
  19. HotRodChassis
    HotRodChassis
    Alliance Vendor
    I use Stahl collectors. You can get them with a couple of different length collector tubes, I think up to 16".
    Here are the Plymouth ones in the car:
  20. I believe it but my eyes don,t....nice work!
  21. kxmotox247
    kxmotox247
    Man.... those are a piece of art for sure. I wish I had skills like that.
  22. flamedabone
    flamedabone
    Makes me want to go throw rocks at my headers...
    When I build mine, I tack teh whole header together, then pop each tube off for full welding, then stick em all back together again.
    Is there a better way???
    Nice work, -Abone.
  23. donut29
    donut29
    from canton MI
    two thumbs up they look great nice welds I wish I could do that
  24. HotRodChassis
    HotRodChassis
    Alliance Vendor
    A better way, probably not. Everyone is different. But I weld as I go and just plan as best I can. Sometimes you end up building from the head, and then at some point where you'll be able to weld all the way around the tube, you start building from the collector. Equal lengths are a bit different in that you've got to know how long each section is as you ***emble a primary. And you've got to decide on what your personal tolerance will be. Mine is within 1/2 to 3/4 of an inch for all the tube lengths to be the same. Do I always make that? No, but most of the time I get pretty close.
    Dropping a hit of acid usually helps you see where each tube is going to go too. :)
    (NO! I don't really do that.)
  25. damnfingers
    damnfingers
    Fire breathing artwork...
  26. HotRodChassis
    HotRodChassis
    Alliance Vendor
    You can! It just takes patience and practice.
  27. F'n-100
    F'n-100
    Just plain ***y.
  28. hemi coupe
    hemi coupe
    from so-cal
    Kevin, Amazing work on the headers dude!! I really enjoy building headers, seeing your artwork is an inspiration.
    Jimmy White
  29. 50dodge4x4
    50dodge4x4
    So, you going to do a header build tech? Like to see something like this in process....long as your doing it. Gene
  30. HotRodChassis
    HotRodChassis
    Alliance Vendor
    Yeah, I could do that. I've got a set on Stripped for Action I have to build. But it's not going to be during Tech Week. If that's ok with you guys and Ryan, I'll put one up.
