Heater on a hot rod?
Discussion in 'The Hokey Ass Message Board' started by Painterman, Dec 1, 2007.
  1. movingviolation
    movingviolation
    Fork lift heater;) Also found on older construction equipment
  2. HOTRODPRIMER
    HOTRODPRIMER
    Yeah,,I have one in my 32 sedan,,,won't keep ya toasty but it will keep ya from freezin'. HRP
  3. Brandy
    Brandy
    from Texas
    YUCK. It's mother should have eaten that thing at birth.:eek:
  4. the one in my '47 is pretty small. it has the defroster tubes but you can modify it to sit closer to the firewall.
  5. i have a home grown heater , i didnt make this thang i really dont remember where it came from or who actually built it i have no use for it and its to damn big for my 37 ..
  6. Gas Huffer
    Gas Huffer
    Mine will be in a '58 Apache, but after last winter and now as we're getting into a new one, I'll be putting mine in. Nothing pisses me off more than having to stop two or three times on the way into work to s****e the inside and outside of my winshield. I just have to get off my *** and relocate the battery and install it.
  7. 34Fordtk
    34Fordtk
    I have a Southwind, has anyone ever converted one of these to water???
  8. Roothawg
    Roothawg
    I'll be danged...I'll hafta check that out. Good idea!!
  9. de-fenders
    de-fenders
    I have an old Southwind, and someone told me of a magazine article on how to gut it and add a ceramic 12v heater. Anyone done this? Seems alot cleaner, not having to worry about lines and all..........just wondering out loud:cool:
  10. RopeSeals???
    RopeSeals???
  11. Thats why I gave the old fan the flick and went with the 7" OD elec fan. More air, more reliable and less room needed to mount it nicely inside the car.
    Rat
  12. RopeSeals???
    RopeSeals???
    You can use a universal choke cable to control a "pull to open" heater valve in the inlet hose... For a 5/8" hose inline valve look for a Four Seasons P/N 74627 or Chrysler P/N 4085564
    ...or you can use a manual valve in the hose, block, or manfold
    PM me with your fitting and hose sizes and I'll get you a P/N
  13. 50dodge4x4
    50dodge4x4
    So, on my 39 Plymouth I still have the original heater in it, but the core was replaced and it has a 12 volt motor replacing the original 6 volt one. The car is a coupe but the window seals ****. Even at 45 degrees this thing ****s. The fan runs and it moves air but the the air coming out is luke warm, even though the hoses are both too hot to hold onto. Just not making much sence to me....
    The heater in my 50 truck is also an original unit. It too has had the core and fan updated. That one will roast you out, but the windows are always fogged up. Thought maybe the core was leaking, but after pulling it, inspecting and pressure testing, the core is good. The truck is pulling outside air, while the coupe is recircling inside air. Thought maybe the outside air was the problem with the truck so I covered the opening, made no difference. The truck is driven through the winter, the fogged up windows is a concern. I have one of those window washing squeegies to wipe the moisture off the inside of the windows. I've even installed a 12 volt fan on the roof blowing at the windshield, helps a little, but is real slow at clearing the gl*** in one little spot.
    If I could get 1/2 the heat from the truck into the coupe, and have the dry air from the coupe in the truck I'd be a happy camper. I'm not real enthused at the thought of cutting a hole in the coupes firewall, somehow I think it must have worked in 1939, it should work now. Any thoughts? Gene
  14. I go pogo
    I go pogo
    My flatty puts out plenty of heat, sort of a 280 cc heater. Now if I could just turn it down in the summer!
  15. HOTRODPRIMER
    HOTRODPRIMER
    Send Shane a PM and ask him about the small heaters they have at southern rods,,,or check them out online. HRP
  16. N312RB
    N312RB
    from Burlington
    Did anyone ever figure out what this is?
  17. GlenC
    GlenC
  18. hemifarris
    hemifarris
    If you look at the pictures in Brandy's post you'll see the Firestone name tag at the top........
  19. Johnny1290
    Johnny1290
    I just wanted to chime in and say there's nothing wrong with running a heater. I don't see what the point is of being miserably cold inside your car, unless its just a show car or something. I'm getting one of the heating/ac units sold by a hamber for $600 complete, but you have to get the hoses crimped.
    http://www.freewebs.com/luckysrodandkustom/coolonlyackit500.htm
    If someone thinks it looks ugly, big deal, I want to be comfortable.
    I didn't hear anybody suggest it so I will, I think insulation couldn't hurt in keeping the heat in and cold out.
    This thread is excellent:
    http://www.jalopyjournal.com/forum/showthread.php?t=51399&showall=1
    You can make your own lizardskin for cheap, I paid $10 a gallon for the microspheres and $5 for oops paint at home depot. Works great!
  20. Fishtail8
    Fishtail8
    Anyone thought about using a rear window defroster blower motor from some of the 60-70's fullsize cars? I think most of them just were a blower motor to move air, but were there any that might have had a 12V heater built into them? Anyone remember?
  21. Engine-Ear
    Engine-Ear
    Alliance Vendor
    heat is OK...keep warm but find something kool to make it happen with!
    Fall (AND WINTER!) is comin soon...
  22. 2-TONED
    2-TONED
    there are sooooo many old cool looking heaters - get one & put it in!
    HEAT IS GOOD!!
    my truck has an 'old' early 40s 6 volt hot water heater under the dash with a 3 speed switch & i had it on tonight on my way home it'll cook ya right out & its probably been in the truck since the early 40s & its still heatin!!
    if it didnt have one already i would be putting one in.
  23. Irish Dan
    Irish Dan
    I bought 2 heaters at the Advance Auto Store where I work part-time. They're both a polymer plastic type of construction; and will fit up under the cowl of my 27 T RPU; One has a directional up draft that serves as a defroster; they're 12 volts units, & can be easily wired to a toggle switch in the ****pit. They REALLY put out the heat! for $20 plus bucks each, they're a bargain ! I haven't decided which one I'll run when this project hits the bricks, though. I've driven in 34 degree temps before out here in the midwest, & obviously survived the 65 mph on the interstates, etc; BUT...I don't care to do it again anytime soon! I like comfort, & I'm not sado/machismo when it comes to doing what I love best: Cruising! My 2 cents only.
  24. Engine-Ear
    Engine-Ear
    Alliance Vendor
    Irish Dan, how many watts do the heaters you describe dissipate?
    Just a heads-up for the non-technical: Be sure your electrical system has enough amperage to handle the load of a heater!
    P = I x E ... so for example, 60W draws 5A at 12V.
    ...hope this helps.
  25. Fishtail8
    Fishtail8
    Is it possible to get some pics or a p/n off those babies?
  26. gnichols
    gnichols
    from Tampa, FL
    I very much like this... Gary
  27. reefer
    reefer
    I bought this heater for my roadster...really nice Art Deco design.Both them little doors open so you can direct the airflow.It should at least keep the temp above freezing..hopefully.
    or I could always get a pair of these...not sure I`d want to take `em off though lol
  28. skwurl
    skwurl
    Street rods have heaters. And pastel paint jobs. And air conditioning. And gay wheels. And the year of the car embroidered in the seats. And aww screw it
  29. Django
    Django
    from Chicago
    Yeah, all the cool vintage heaters that came in these cars when they were new are gay too. Whatever dude. How cold does it get in Tennessee? 50°? :D
    Heated seats in a hot rod = gay.
    A 1935 heater does not = gay.
  30. Ratty55
    Ratty55
    from Frohna,MO
    I'm working on putting a heater core in one of the stewart warner south wind heaters. Just an idea, i haven't finished it yet. 90's Ford festivas have a heater core small enough to fit behind the shells.
    Justin
