Homemade intake manifold. Aybody done it?
Discussion in 'The Hokey Ass Message Board' started by 34Hupmobile, Nov 12, 2004.
  1. A lot of things I don't understand. One of them is why shouldn't or couldn't I build an intake for my L6 myself. Is there any specific reason it would have to be cast? Why couldn't I make one out of plate steel?
  2. seymour
    seymour
    from PNW
    theres no reason you couldn't. i've modified some of my stock ones before.
  3. Mike Rouse
    Mike Rouse
    No reason why you could not make an intake manifold.
    3/8" flanges on the head and 16 ga sheetmetal all brazed together would work great, could even be made odd looking.
    Use tubes and rectangular tube too.
    I think brazing would be best as it would cause the least amount of distortion. You could jig it up on the head and braze away after first tack brazing all the pieces. The flux coated bronze rods are low cost and an oxy acet torch are the major players.
    Mike Rouse
  4. Piece a cake. You can build a log type with exhaust pipe and a log plenum. Or you can make a simple plenum box for your carb if you're building it for a single carb.
    I'd probably wire weld it myself, but I've brazed 'em when all I had was a torch.
    Sheep metal/tubeing intakes have been around forever. I think they cast me because its easier to m*** produce and keep 'em all the same.
  5. Slag Kustom
    Slag Kustom
    build it on the head weld everything nice before you remove it and have the flange surfaced and there will be no problems. I have made some for harleys and have them hpc coated when im done to give a nice look to them.
  6. Mutt
    Mutt
  7. laverda
    laverda
    From an old HAMB post ...... for a hemi but you get the idea (apologies to the dial ups) [​IMG]
    1
    later,
    papa al
  8. whizzerick
    whizzerick
    The Vaporizer!
  9. Jonnyhotrod
    Jonnyhotrod
    Laverda,
    Could you repost that Post... Only pic 2 came out. It looks like a sweet article, and a fun project. Thanks. Or PM me and you could email it, if you would be so kind. Thanks.
    Jonnyhotrod
  10. Special Ed GT
    Special Ed GT
    from Denver-ish
    [ QUOTE ]
    [/ QUOTE ]
    "Ordinarily a multi-carb V-8 manifold sets you back $75 or more"
    They got that right! [​IMG]
  11. Jonnyhotrod
    Jonnyhotrod
    Would love to see some old U-Fab plans/instructions if anyone's got 'em....
    Jonny
  12. AV8Paul
    AV8Paul
    A friend of mine is putting a 308 Hudson six in a '29 Es*** roadster. He's making his own intake and modifying a jeep header sys for this engine.
  13. AV8Paul
    AV8Paul
    headers
  14. AV8Paul
    AV8Paul
    Here's the factory relief on the Hudson 308 flathead.
  15. sodbuster
    sodbuster
    from Kansas
    Harlan/Spank made a 3/2 a couple of years ago out of square tubing and flat steel and alot of guys mentioned that it would not work. But he did it and I saw him this past summer on the salt with the intake still there. I mentioned it to him about the intake and he just shrugged it off. I have a pix that I can post in the next couple of days.
    Chris Nelson
    Kansas
  16. Kerry
    Kerry
    Here's one a friend made for his hemi back in the day. Flat steel and square tube, just like the one Sodbuster mentioned. Duane has been running this one since 1957.
  17. dehudso
    dehudso
    *****in hudson pics there. Have him relieve that thing to the head gasket, and it should fly. Any more pics?
  18. DollaBill
    DollaBill
    A bit OT, but Hogan does it everyday...
  19. nero
    nero
    in the old days they sold u weld em log manifold kits..maybe som one should start making them ? every one today has a mig..
  20. Reverand Greg
    Reverand Greg
    you can use aluminum and do anything you want sidedrafts four barrels anything,import kids do it alll the time
  21. Pontiac Slim
    Pontiac Slim
    Hey..
    I made a t-ram for the 455 thats in the A COUPE.. NOT THAT HARD BUT DO WELDING WHEN INTAKE IS BOLTED ON DUMMY SET UP.
    PONTIAC SLIM
  22. Stone
    Stone
    Great post. I was looking for info on Crower U-Fab intakes from the old days and came across some threads that linked this one. Cool ideas
  23. Here's mine.....again. :)
    Weber side-draft on an Iron Duke.
  24. Moloko
    Moloko
    I'm planning on making one this winter.
    Here is the one my friend just got for his race DSM. Has velocity stacks inside :eek:
  25. Twisted6
    Twisted6
    I am remaking the tunnle ram intake out of alum right now.The first one was made of sheet metal and so was the flat 3x2 intake.The Tunnle ram intake was built for my 3x4 (450 holleys) Building them was not hard to do,Just take your time and Use a head as a jig when your ready to start welding it up.It will help a Great deal to keep it straight.
  26. Flatdog
    Flatdog
    How the men do it.No not me flat 32 sometimes on hamb did this, also did own heads.
  27. budd
    budd
    boy thats nice, alot of work, have any pics of the head tooling? anymore info around on this job?
  28. Reverend Bow
    Reverend Bow
    from Yuma, AZ
    Yup... When no one makes a manifold for your engine, because it isn't a HONDA...
    Here is Mine...
    Started with some 0.75" 6061 T-6 plate and a Intake gasket.
    Ended up with this... After a few math calculations for length of the runners and such...
  29. Flatdog
    Flatdog
    Here are some pics of a stub manifold that my kid fabbed up for me .Not bad for a 19 year old.
    charleyw likes this.
  30. Reverend Bow
    Reverend Bow
    from Yuma, AZ
    Flatdog, that is a slick set-up...
    Your boy must have had a good teacher
